Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Why does my screen show irregular discolored vertical stripes?
The screen shows a set of lighter stripes, vertically (top-bottom), in various widths. For example, if i choose a green regular color for the Finder, then the screen is marred by a certain number of vertical bars (lighter green in this case) as if a painter had done these.
Is it the screen, or the lightning of the screen (fluo lamp?)
The problem appeared about 15 months of normal useā€¦ out of warranty!
Bertrand Morin
Score 1
1 Comment
Exactly the same problem, even the age of the tablets. I bought one at Staples, and later on one at Amazon. They both have the same issue. Strange...
I contact ASUS. They quoted a repair price equal to the purchase price. Definitely won't buy another from this brand. The two are now sitting in the closet waiting for some kind of solution.
by
Add a comment
Chosen Solution
could be the LCD display, or possibly the graphic card. Perhaps backlight related, but I'd only suspect that if the stripes were NOT confined to exact pixel-aligned lines.
a couple questions and debugging ideas:
1) are the striped always fixed in the same position? or do the come and go depending on what's displayed?
2) do they go the entire height of the display, right to both top & bottom edges?
3) what happens if you change the screen resolution, in System Preferences/Displays - are the lines in the same physical position or do they "move" with the display image?
4) if you take a screenshot (Cmd-Shift-3), do the lines appear in the screenshot, or not?
the above might give some clues if it's graphics card/graphics memory related or the LCD screen.
1 Comment:
Stripes are not clearly defines by pixel, more of vertical zones. Always fixed and independant of displayed content, including Finder Colours especially). Yes, from top to bottom edges. Changing screen resolutionhas no effect. Lines show on the images/pictures.
by
Add a comment
Most Helpful Answer
When you accepted the answer people stopped looking at the question. To try to isolate the problem, hook it up to an external monitor and let us know if the problem persists.
Score 2
Add a comment
The stripes are not clearly defined, they have a blurred effect, pastel like.
I have given up on the problem.
Berrand
Add a comment
Add your answer
Bertrand Morin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 17
All Time: 3,716
