2
Score
Avatar
Logikism
91
Asked
Can I clear the serial number?
History
is there a way to clear the serial number from my machine or change it to a different one???
Edited by
I'm not touching this till you tell me why.
mayer,
Post Answer
6
Score
Avatar
rdklinc
15.3k
Answered
Accepted Answer
PermalinkHistory
I don't think the serial number is part of the CPU itself, but rather part of the logic board, and like MacHead mentions, a logic board swap is effectively the only way to change the serial number.
New logic boards often come with no assigned serial number, and there is a technical procedure required to put a serial number on the board (typically you would put onto it the serial number of the board you are replacing). For good reason, this procedure is generally only known or available to the manufacturer, and not something we as mere mortals have easy access to.
I don't know if you've run across this, but occasionally I've found a laptop that has no serial number, or a serial number typed out in lower-case (typically they are upper-case). This is a giveaway sign of a replacement board, and indicates that the tech was too lazy (or not knowledgeable enough) to put the old board's serial onto the new board, or that they put the number on, but typed it in lower-case. When I was responsible for server environments, Dell techs would always forget to put the serial number back during a motherboard swap, and I would always be annoyed and ask them to come back.
On many PCs and servers, the serial number can be changed in the BIOS, and although I'm not sure, I suspect on Macs it's done in Open Firmware or something similar.
+ nice, I've also seen some units with the same serial number on the logic board, keyboard and case.
mayer,
thanks! that sucks only of price but owell
Logikism,
I used to work in an authorized apple service department. And yes there is a bootable(firmware and I'm sure there's an efi one as well) disc that allows you to change the serial number. In either case at the time (Power PC Days) only the apple service depots were allowed to have these discs. But us none apple owned service departments could not get them. Until one day after receiving a machine from apple service one was left in the optical drive of an ibook g4. This was during the ibook logic board replacement days where us lowly none apple owned departments had send in those machines to apple to have the logic replaced. As if we weren't able to change them ourselves. Needless to say, the first thing i did with the disc was image it then change my serial number to my screen name for aol and some numbers at the end. I think i might still have the disc, actually.
buddilla,
Show 1 more comment
Score
Avatar
machead3
12k
Answered
PermalinkHistory
The sn# is not "user" changeable
I don't think there a way to change it short of a complete logic board swap.
Good Luck,
N.
Edited by
Add Your Answer
