0
Score
martinjenn
43
Asked
Why does my iPhone keeps shutting down many times a day?
I have a 16GB 3GS that is a little over a year old. For the past two weeks it keeps turning it self off. I have to hold the power button to turn it back on. Some days it will not do it at all, but other days if will not stay on more then a few minutes. I bought a new battery from Ifixit, thinking that is the battery was shot. But this did not resolve the issue. What next step should I take? Can it be the pin connector, or is this a problem that I can fix. I do not want to upgrade to the iPhone 4, I want to wait until next year to get a newer model. Please help me if anyone can. Thank you in advance.
4
Score
markus weiher
22.6k
Answered
Accepted Answer
sounds like a contact issue to me - but it's hard to tell what part fails.
maybe you should run a few tests - try to find out in wich situations the phone shuts down.
mostly phones have those problems when it's warm or the get bent and so on (everything that can happen when a pone is in the pocket)
0
Score
oldturkey0
87.9k
Answered
I recently had the same problems with my 3GS after updating to the OS4.1 I even came up with a 1604 error and thought I bricked my phone. The solution for my phone was to return to the older firmware. I accomplished this by downloading an older firmware from http://limitededitioniphone.com/where-ca... then I did the following:
Turn off iPhone – Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider
Press and hold down the Home button until a yellow triangle with a text which says Please Connect to iTunes appears
Plug the iPhone into my PC (windows)
I already had Itunes running so make sure its on.
iTunes prompted with a message that said iTunes has detected an iPhone in recovery mode. Click OK.
You will be taken to the iPhone pane. Hold down the Shift key (in Windows ) and then click on Restore
The step above will open up a window to allow you to select the firmware software file you would like to use to restore the iPhone. Browse through the folders (Located in my case under C:\Documents and Settings\Oldtur
Select the old firmware file that you downloaded i.e.iPhone2,1_3
Wait for the full restoration process to complete, and the iPhone will be restored to state based on firmware file you selected.
It does sound complicated but is really not that bad. Hope I got all the steps outlined to follow this. I do not know if this will resolve the issues that you are having with your phone. Also remember with a restore it is very likely that you will loose all your info and music on your phone.Best answer I can give you and I am no expert in this :)
thanks sir for ur detailed summary but that $^!@ dont work i legit sat here and played and did everything i ^^#!^#% could n this #$*! still isnt working and ive been ##&!*!$ sitting here for over 2 hours $### APPLE
Try calling Apple... After all they created the phone!
Sarah,
I Have the same problem as yours in 3GS happed after I updated the new OS4.1 software. I changed the battery! no luck! I rest all to manufacture, still no luck, Hold both buttons five second till shut down, still no luck! So what else I can do? The phone out of warranty! :( :( Please help! Thanks
Ahmed,
