The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Questions View all
DC IN Voltage Fails TechToolPro Diagnostic
I have a MacBook Air that sometimes doesn't startup at all.
So I ran the TechTool Pro 8 diagnostic on it and it has a sensor failure: DC In failed at 16.96v.
Does anyone know if there is a way I can fix this other than a new motherboard?
Score 2
1 Comment
You may be using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
by
Add a comment
Chosen Solution
The Mag-Safe is built into the I/O board. There does not seem to be a repair guide for this machine but there is one for the A1466 2012. Take a look: MacBook Air 13" Mid 2012 I/O Board Replacement
Score 2
Add a comment
I just replaced the part for a brand new one from IFIXIT and it didn't fix the problem.
I'm still get the DC-in Rail 0 Failed at 16.67 V.
Anybody else managed to fix it?
thx
1 Comment:
You'll need to trace the voltage from the I/O board back to the main board as you have a disconnect along the pathway.
by
Add a comment
I had the same issue and I fixed it by using the right charger. No more errors now!
5 Comments:
Right…charger??
by
Are you saying that you can use a Thunderbolt 1 port to charge a MacBook Air??
by
Use a genuine Apple 45W charger. Fake chargers do not have a stable voltage and can cause this issue.
by
Oh, the *correct* charger! I thought he was charging through the right side—i.e. the Thunderbolt port.
by
He was using the wrong power supply. The Air uses a 45 watt power supply at 14.5 volts. All the other laptop products use a 16.5 volt supply. So if you hook up a MacBook Pro power supply you're going to see 16.5V to 17V on the DC-in rail (depending on the accuracy of the sensor).
by
Add a comment
Add your answer
randy4 will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 6
Past 30 Days: 30
All Time: 3,293
