Score
delamare1
23
Asked
What causes gray screen and a repeating series of 3 beeps?
My intel-based iMac running 10.5 will not turn on. The startup tone is heard, then a gray screen, then a continuing series of three beeps. The response is the same even when the shift key, D key or T key are held at startup. Suggestions? The computer did not suffer any bumps or bruises.
4
Score
Gabe
5.2k
Answered
Accepted Answer
According to Apple this means that the RAM does not pass the test. There is a RAM DIMM in your computer that is defective. Please follow these directions to take out your ram. Start by taking out one, then starting up the computer. If it works, that RAM DIMM (or RAM stick) is defective. If it doesn't work then its the other DIMM, so reinsert the one you just took out, take out the other, and start up your computer again. In the unlikely event that it still doesn't work, it may mean that both DIMMs are fried and you need to order some ram and test it out with that. Your iMac has a maximum ram capacity of 6 GB.
iMacs have a different diagnostic set, why, I am not sure, maybe because it has no power light. http://support.apple.com/kb/HT2538
Gabe,
0
Score
delamare1
23
Answered
0
Score
John
Answered
