Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
New battery recognized but will not run on battery
Early 2011 MBP battery not charging, indicated 0% charge and "Replace Now". Computer is from an office environment and has NEVER suffered any liquid spills, drops or other damage, it is in like new condition. Purchased and installed new A1382 battery but will not run without AC adapter connected.
Computer runs normal on A/C power but is not charging battery. LED on MagSafe stays bright green. Tried another 85W MagSafe adapter from wife's MBP, same problem. Bought a new Apple 85W adapter to be absolutely sure, same problem. System runs fine on A/C power but LED will not change color and battery not charging. With A/C adapter connected, I reset SMC and NVRAM but no change. LED on MagSafe did not change color either.
Battery meter on side of computer does not work unless A/C adapter is connected, then all but last LED will light up. Ordered and installed MagSafe Board from iFixit, no change, reset SMC and NVRAM again, no change in battery status. Booted AHT (Apple Hardware Test) will not get past the following error "4xxx/4/40000005: Battery"
Returned and received another A1382 battery, re-did all of the above, same problem.
Suggestions?
Score 2
2 Comments:
I have the same problem! Did you find a solution to fix it ?
by
@leocorona - Sadly this one slipped through the cracks. How about creating a fresh question with all of your details so we can see if we can help you.
by
Add a comment
Maybe the battery indicator needs to be replaced if not then mobo is toast
Add a comment
I've seen that error twice in the last 5 years and both were from generic batteries installed. In one instance, it slowed down the computer to the point it was unusable
3 Comments:
The problem is from generic battery. I agree with https://www.ifixit.com/User/214955/apple....
I have an early 2011 macbook pro.
by
so whats the suggestion here ? Buy Apple Original ?
by
I removed the battery but after a few days the problem come back. I beleive that is software bug and not the after sale part.
I try to find what happen.
It's unexpextable that what happen....so much money for these laptops....
by
Add a comment
I have the same error 4xxx / 4/40000005 the battery is from third parties but the load everything works me well only in the test I get that error
Add a comment
Add your answer
ashstreetaudio will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 19
All Time: 2,221
