Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Why do I receive error code 29 when I attempt a restore?
During a software update using Itunes the update process was halted and an error message was displayed that said that an unknown error ocurred and that the update was not possible. Now the phone is not recognized by Itunes, and will not power up. When I attempt a restore I receive the same message that the restore was not possible due to an unknown error (code 29). Any ideas would be appreciated.
Score 7
4 Comments
I have tried a restore from another known good computer and have also verified that both computers fucntion normally. I have three other iPhones that connect and update as they should via itunes and both computers/cables. I have tried numerous restore functions and the error code I receive is 29 sometimes and 13 other times. The phone does power up now however, it prompts me to connect to itunes--which of course leads me back to the unable to restore error codes.
by
I just fitted an 0435 on the basis that this would fix my 29 error but no joy.
by
Try alfreds advice and swap the battery circuits
by
on my 3gs it was the wrong battery, i had it replaced and it was not the correct battery and the replacement battery was APN 616-0432 and it worked no more 29 error code was able to restore phone after replacing battery.
Thanks
by
Add a comment
Chosen Solution
Our batteries eliminate this issue.
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
Score 19
8 Comments:
There is also a workaround you can recommend your customers which involves nano Editor in which you prevent iTunes from communicating with Apple servers. I have used this remedy myself after days of different error messages while trying to restore my phone.
by
Do you have a link? This sounds very interesting? I hope it's for macs and pcs... Cheers, Jen x
by
Yes Polly...It's for Mac and PC's. Look at my answer below.
by
I have a jailbroken iphone 4 and any type of restore is a pain in the arse without this workaround. No other recommended fixes worked for me but this one.
by
Thanks to Fixit. I have changed the battery on my 3gs with the APN:616-0433 and its cleared the Error 29. My phone now successfully restored. Thanks Again !!!
by
Show 3 more comments
Add a comment
This answer was originally to another question.
This nifty little trick has stopped all iTunes Error messages dead in their tracks. Give it a try. It worked for me after two days of trying to restore a phone in recovery mode.
Step 1. On your Mac, go to your ā€œApplicationsā€ folder.
Step 2. Now navigate to the ā€œUtilitiesā€ folder.
Step 3. Launch "Terminal".
Step 4. Type "sudo nano /etc/hosts" (without quotes) and hit return.
Step 5. Enter your password
Step 6. Use the down arrow key to find the ā€œgs.apple.comā€ entries. Once the cursor is in front, make sure you comment out the line(s) by entering ā€œ#ā€ in front of the text.
Step 7. Save the file by pressing CONTROL+O.
Step 8. Exit the nano editor by pressing CONTROL+X. I found ctrl X didn't exit for me, so Try "return' key after Control O to save and exit.
Step 9. Restore your iDevice.
Windows:
Step 1. Start ā€“> Programs ā€“> Accessories
Step 2. Run Notepad or WordPad
Step 3. Click ā€œOpen..ā€ from File menu.
Step 4. Browse to Windows/System32/drivers/etc
Step 5. In "files of type:" select all documents
Step 6. Open "hosts"
Step 7. Delete all line that has "gs.apple.com" or something like that
Step 8. Hit Save
Step 9. Restore your device
Score 6
9 Comments:
Can someone receiving the 29 error please try this fix and report the results back.
by
thanks your majesty! will keep this link...x
by
No prob. Jen. Hope it helps. ;o)
by
Polly, being that Error 29 usually points to a hardware issue; can u please report back if this workaround is effective for this quirky battery (Error 29) issue? I don't have a device with this error so I can't do the test myself. While trying to upgrade my software I received a ton of different error messages and for 2 nights I could not upgrade/restore the phone, till I found this. But I don't think I received an error 29.
by
It may work to get the os booted but if the problem is related to a non-oem battery with 4.0 then the iphone will still have charging problems and shut off every 10 minutes or when you open safari. (or that is at least what happens when you install the battery after the ios 4.x.x update). But thanks for the info, very usefull.
by
Show 4 more comments
Add a comment
have done some searching for this( have had my own dramas)... some theories are that the software you have downloaded was corrupt or interrupted whilst downloading .or has it been jailbroken?
you can try downloading an old ipsw from your itunes library instead of trying to upgrade as apple only allow the latest version (iOS 4.0.2??)and this may be why error 29 occurs.
try the oldest version you had for your phone (basically giving it it's original os back)
fingers crossed!
Score 2
Add a comment
This battery will work for you: iPhone 3GS Battery
The part number you have is correct. Your problem is probably unrelated to the battery. Here's what Apple recommends doing for error 29: http://support.apple.com/kb/TS1275?viewl...
Product
iPhone 3GS Battery
$14.99
Score 2
Add a comment
From the Apple support site it appears that "Error 23, 28, 29, 1011, 1012, 1611: These errors may indicate a hardware issue with your device. Follow the steps in this article and also attempt to restore while connected to a known-good computer and network to isolate this issue to the device. If the IMEI or MAC address is missing or is a default value, this can also confirm a hardware issue."
Have you tried to restore with another computer?
Score 1
Add a comment
The answer is the circuit board on the oem battery you're buying. Besides facing error 29 you will also notice the battery percentage on your iphone is not reading correctly.
Use the original circuit board on the new battery you bought and everything will go fine. The problem is you will have a hard time taking out the circuit board from the original battery cos its tag weld to it. The method is to apply heat to the contacts and the battery will slide off from the circuit board.
Score 1
Add a comment
Found an inductor near the battery connections on the logic board (flip side) which was damaged (FL1 of 3GS circuit board). This carries messages from the battery and with this inductor gone the battery was no longer reporting. Replacing or shorting this should fix the problem I hope.
Score 1
Add a comment
I had this problem on my 4S. Original battery APN 616-0579. Bought a replacement battery APN 616-0580 (said was compatible, couldn't find a way to order a specific APN). Worked fine until I tried to upgrade the iOS version, then got persistent errors (error 29 on restore). Put back in old battery, and the iOS update went fine.
So every time I have to update iOS, I have to swap batteries, and then swap back. What a pain. I wish they would not claim multiple APN #s are compatible because they are not, they should have this info where they sell batteries and let you order a specific APN #.
Score 1
Add a comment
If your phone originally came with a battery part number apn 616-0433 and have since replaced your battery with apn 616-0431 you may find that you always get an error 29 when upgrading to ios 4.x Some people have reported that apn616-435 also works as a replacement battery and doesn't cause an error 29. Most vendors, including ifixit.com ship 0431 as their 3gs battery part.
Add a comment
i faced the same problem... wanted to install the 4.2 bet of iOS on my 3GS, and got the -29 code.
fortunatly, i had the original battery still somewhere in my desk drawer: after replacing the new fixit battery with the original one, i was able to install the newest firmware without any problems.
@fixit: are you aware of this problem?
Add a comment
I can confirm this issue. I had an APN:616-0431 installed into my 3GS, and it wouldn't install iOS4.x. Restore always terminated with error 29 (forget everything you read in forums about DFU mode etc., it doesn't work anyway). Got an APN:616-0435, and my 3GS is back online :o)
Regards,
Frank
Add a comment
Hi
I had the error 29 for days and tried all sort of things, in the end I decided to try changing the battery as described by many forums, I bought a proper Apple battery APN 616 0435 and one of these from ebay
http://www.ebay.co.uk/itm/IPHONE-3GS-MOB.... ichanged it to the apple one first and still got error 29!! GRRR so i thought what the heck I might as well try the gold business battery....guess what! it worked and is working perfectly now!
hope this helps Wombatt
Add a comment
I have a 3GS 16Gb (old boot rom and original battery was a 616-0431) that was working fine with a generic battery (616-0433) off Ebay on ios 4.1 for a long time but then I updated to 5.1.1 and ONLY AFTER A FEW DAYS it started rebooting every few minutes and my battery charge % would not go above 80%... Spent over a day trying to fix (restore) it - no luck - always ERROR 29 and stuck on Itunes recovery screen.
I even downgraded to 4.1 and forced it to recover using tinyumbrella (it crashed error 29 right at the end of the restore process) and now it reboots every few minutes even on 4.1!!!! Sooooo, I just ordered one of these ifixit batteries and will let you guys know if it works out ... I think its total bs that the Apple upgrade causes this battery issue...
UPDATE 7/18 : **** The ifixit battery did not do anything for my 3GS - still the same exact issue.... ****
3 Comments:
did you try the fix suggest by Majesty?
by
Oldturkey I did try that, step by step and even tried it again, still no go. I emailed ifixit and Scott is replacing the battery :) I hope that there is nothing else gone wrong with my 3GS after ios 5.1.1 :/
Personally I think its #%^^ ridiculous that because of the latest ios you cannot have a generic battery. I am glad that Apple does not make cars lol.
by
UPDATE : After trying several batteries (ALL OEM Apple and 2 of these ifixit batteries) the iPhone still did not work. I have given up on it and sold it. I think it is a bunch of bullshit that an "update" can do this. I wonder sometimes if its Apple's idea of forcing people to get newer phones??? Not me!! I will NEVER buy an Apple product ever again and neither recommend it to ANYONE.
by
Add a comment
Hi I tried the fix suggested by Majesty about deleting the gs.apple addresses in the hosts file but it didn't have any affect. Wish it had. This is getting me down. I'm reluctant to buy another battery until I know it will work with my 3GS phone. Unfortunately I do not have the original battery anymore so am not quite sure what to do. I was hoping for a software fix.
Add a comment
Beware! The battery you bought is fake. Only fake batteries cause iPhones to get sudden shutdowns, wrong battery status and the error 29 which happens during restores.
Add a comment
I had the problem with eternally rebooting iphone 3gs after replacing the battery with a non original replacement battery. reboot every minute or so, no update on battery loading etc.
Opened the phone and the label said "Battery for Iphone 3G". It was raining and I didnĀ“t want to go to the store and I thought f*****g drm issue. But probably solvable with a soldering iron.
I disassembled the original battery with some caution. Then I measured what was + and - on the tabs spot welded to the PCB. Marked out was was + and - and did the same for the replacement battery. Then I transferred the PCB from the original battery and attached it to the new. Problem solved! no rebooting. now i have a 1600mah battery in my 3gs, wonder if it will work better than the original, Exciting but nothing has exploded yet ;)
Add a comment
This only seems to be a problem for iPhone 3GSs that have had a replacement battery.
The iPhone I fixed was perviously repaired by an amateur, screws missing, antenna spur bent etc.
Add a comment
as above, i get to step 6 but done see a gs.apple.com line guess i am stuck with a paperweight
1 Comment:
I don't see it either
by
Add a comment
Majesty..can you explain to me what you mean by this step for restoring with Windows:
1 Comment:
yes I am wondering also
by
Add a comment
hard reset, put out your sim card, connect to itunes and restore.. fix my problem. thx
Add a comment
One iPhone 4S with earlier restore error code 29 started working after battery replacement. Back panel was ruined so no hope for battery warranty. There was indications of battery failure beforehand because battery ran out quite quickly.
Low cost and easy maintenance process with right tools is in my opinion worth of trying.
Add a comment
Add your answer
duanemoore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 71,446
