2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
How can I clean my laser disc drive?
Hi there!
I have had my MacBook for almost 4 years and had no problems until recently. A few days ago, my DVD/CD reader drive decided to stop reading discs. I saw that many other people online have had this issue and that it might possibly be because there is dust or debris within the drive.
My Macbook ejects and DVD or CD that I insert after making a weird reading sound (not smooth sounding, as it did previously).
I saw your iFixit guide on replacing the drive, but if I wanted to just clean it, what would be the proper procedure so that I don't damage the drive (any more if it is damaged) in the process?
Do you think it's even possible that it's just dirty since it's not reading CDs or DVDs or do you think it's more likely that it's actually damaged?
Thank you for any help you can give!!
-Amber S.
Score -1
Add a comment
1 Answer
Chosen Solution
Hard to say if the drive is bad. With that said, you might try cleaning the lens by getting a CD/DVD cleaning disk from Radio Shack. This disks have a micro brush that can clean the lasers lens. You could also try using some can'ed air. A short blast or two should do it (make sure you don't spray the liquid)
Score 2
Add a comment
Add your answer
Amber will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 887
