Repair guides, troubleshooting information, and service help for refrigerators manufactured by General Electric (GE).
241 Questions View all
GE side by side refrigerator, freezer
GE side by side Refrigerator is not cooling and freezer not freezing its making a ticking sound like a clock. Pull fridge out it sounds like it coming from the control panel on bottom right
Score -1
1 Comment
What parts did you replace?
by
Add a comment
Most Helpful Answer
Take a look at this link, Why are my fridge and freezer not cooling?
Score 1
Add a comment
The clicking noise most likely means the hard start capacitor is bad and well need replaced. With out the hard start capacitor the compressor will not turn on.
If changing the hard start capacitor does not fix the problem then the compressor may be bad.
Score 1
Add a comment
Also check the evaporator fan motor. This is usually located on the freezer side. If it's not turning then the fridge will not operate properly. You can hear it / or not on that side. Tear down the freezer side and look behind the panel door. You may have to remove the ice maker to properly get to it.
As a temporary fix you can spray it wil silicone lubricant to get it back going again. But like I said that is temporary. A full replacement is needed.
May as well since you tear it down already.
1 Comment:
This might have been good information 7 months ago when the question was asked.
by
Add a comment
my power went out now my ge side by side control panel wont light up and the compresser is not running is there any way to reset it the model 3gsl22jftabs
Add a comment
Add your answer
Swright will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,401
