Score
Avatar
thinkerer
13
Asked
What order do the LCD cables get reconnected to the inverter?
History
I had followed the hard drive replacement procedure, and didn't mark my 4 LCD cables that go to the power.
Now my computer wont turn on at all, no fans spinning.
Edited by: Kyle Wiens ( )
Post Answer
2
Score
Avatar
matthewfrey
1.7k
Answered
PermalinkHistory
It does not matter, the Two Inverter Cables at the top of the LCD plug into the two upper Cables, and the two near the bottom plug into the the lower cables. Polarity is in the cable itself, not the selection of the cable.
Score
Avatar
rj713
39.1k
Answered
PermalinkHistory
Hi, including the part of the teardown concerning the inverter cables.
Hope it helps. Ralph
http://www.ifixit.com/Guide/Repair/iMac-...
0
Score
Avatar
varsityanchor
817
Answered
PermalinkHistory
I reviewed the teardown of your model iMac. I also own an iMac and have replaced my HDD 2 times. I never actually disconnect the inverter cables.
This is going to involve trial and error since there are no distinctive differences in the cables. Try different combinations with the cables and you will eventually get it.
Im sorry i cant be of more help to you but use caution and don't give up.
Cheers!
-Varsity
BOOOM sorry, could not help myself ;) I would see if the routing of the cables has any clues. Not having an iMAc - I can't even take one apart. I guess there will be ground, backlight, shield? - realy hard to say from here, just, I hope it's not BOOOM
11team,
0
Score
Avatar
Patrick Coan
Answered
PermalinkHistory
Same problem, didn't even disconnect the inverter cables, now will not power on. WTF.
Weird. Was plugged in, unplugged from unit and plugged back in and that did it.
Patrick Coan,
0
Score
Avatar
Jason Lindholm
Answered
PermalinkHistory
Just finished with a hard drive replacement myself on an iMac a1224. My inverter connectors on the motherboard had a little dot on them. I connected all four cables with the clip on the dot side. Powered it on and it works perfectly.
Add Your Answer
