Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 Questions View all
Cannot format new HDD under 10.6?
There is a lot of discussion all over the web about it, but i couldn't find a solution yet. When i try to erase or format a brand new ATA 1.8" 80GB drive (Samsung HS082HB/A) using disk utility i get this error message "POSIX reports: The operation couldn’t be completed. Cannot allocate memory"
Under 10.5 it's similar, it only says i/o error instead. The disk seems to be named nearly randomly, things like SAISQNC or else and sometimes it shows a capaticy above 2 PB.
I think its the disk controller or the ZIF cable. Great if somebody has a different suggestion.
Score 2
Add a comment
Most Helpful Answer
Try reformatting with another OS, Windows or Ubuntu. You can run a VM of Ubuntu on your mac and mount it onto the VM and use disk manager in ubuntu to do it.
Score 1
Add a comment
Google GParted; a free piece of live sofware you won't need to install, you just need to burn it on a regular blank cd and startup your computer from there. That should format your drive.
Score 1
3 Comments:
I tried both, yours and Gabe Chais solutions, and failed. I start to believe this is really a hardware fault. GParted is actually included in Ubuntu 10.04 but couldn't do any good. Thanks to you two anyway. ++
by
Update: Tried GParted Live on it's own and still no luck. For a change it couldn't see a drive at all. I will have a close (ohmmetered) look at that ribbon cable. I'm pretty shure the HDD itself is fine.
by
It turned out that the HDD itself was DOA. Bummer. But it will be exchanged
by
Add a comment
Hi remacberlin,
I am looking for a source of Mac parts in Europe.
Sorry - didn't know any other way to reach you!
1 Comment:
Remacs web site is listed on his profile, www.re-mac.de
by
Add a comment
Add your answer
remacberlin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 5,405
