Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
The screen work when I press the corner
When I turn on the laptop, The screen turns gray, Only work if I press the top left corner, At the beginning is quite difficult, I must wait a couple of minutes before the screen work correctly.
Thanks for your help!
Score -1
1 Comment
Probably this machine: Apple MacBook "Core 2 Duo" 2.0 13" (White-SR) Specs
Identifiers: Late 2007 - MB061LL/B - MacBook3,1 - A1181 - 2200
by
Add a comment
1 Answer
Chosen Solution
You have damage/poor connection to that part of the LCD. Replacing the LCD would solve the problem.
Once you have the front bezel off, & the LCD removed from the cover there's a manufacturers' sticker with part number on the back you could use to find a replacement screen.
You might find a working display from a laptop with logic board damage (wouldn't have to be the same color any 3,1 display would work.
Only you know how much money you wan to put in this machine.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
2 Comments:
Don't you think this solution could work for me? Display MacBook Pro A1260 had a loose connection
There, you suggested check the connections, or do you think is a different problem and the only solution for me is replacing all the LCD?
Thanks!
by
Does it flicker when you tilt it? (you didn't describe your problem that way) you said it was gray unless you pressed a spot on the top left edge... two different problems, two different reasons, two different solutions.
by
Add a comment
Add your answer
Catalina Velasquez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 5
All Time: 120
