Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Questions View all
Why my screen is blue?
5 months now my screen is blue (like the photo that i have send you). do you know the reason????
If i take a screenshots and i send it to the iphone 5 and its look perfect like don't have a problem (I send you some screenshots of that. Thank you very much and greetings from Greece.
3 Comments
Looks like a bad LCD to me.
by
Still looks like a bad LCD to me. Have you tried an external monitor yet? My bet is that it will be normal with an external monitor ;-)
by
i dropped my mac book pro in march and it bent the metal bit on the bottomleft corner of the screen, the laptop was fine and nothing else happened. the actual screen was not bent or affected. recently (August) my screen has started doing the same thing as is pictured above (blue tint) can these two things be related? is it likely? my laptop has also been freezing and crashing but the apple store say there are no problems they can diagnose
by
Add a comment
Chosen Solution
That appears to be your Appearance and Highlight color...(what you get when you select text ) change/managed in SystemPreferences->General:Appearance.
If you are not intentionally selecting things your SystemPreferences-Trackpad settings' may be too sensitive, set incorrectly or your trackpad is misbehaving.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
8 Comments:
Nothing happens or change when I go in SystemPreferences->General:Appearance, and change it. Please try to be more instructive or enlightening! Thank you in advance!
I think is not something from Trackpad I think is something from the screen!
by
If it were the screen, or VGU/VGC everything would be tinted.' Your pictures appear to show large sections of web pages that look normal, further there are different rows of pixels that are colored... if it were the display or damaged pixels/circuits the same pixels would always be affected. Try creating a new account and use that if the problem does not follow it's not hardware related. . If an external monitor does not exhibit this behavior, the VGU/VGC is eliminated as a possible source - but if you see the same thing on an external monitor there's your problem. Connect a USB keyboard and mouse (need not be Apple manufacture) then reboot (leave connected). You might also find your problem goes away... if it does I would suspect the top case (as I originally thought).
by
Try deleting the ~/Library/Preferences/com.apple.systempreferences.plist file if creating a new account solves your problem.
by
where i should try to create a new account???
by
~/Library/Preferences/com.apple.systempreferences.plist i try to delete this put nothing change :-(
by
Show 3 more comments
Add a comment
Boot up in Safe Mode (hold down the Shift key) when starting up. Let us know if the problem persists, this will tell us if the issue is hardware or software related.
Score 1
4 Comments:
I am sure that the problem is not from the trackpad because also the video have problem, on the video appear small white dots and some lines!
by
I had put the cd for hardware test and its says no problems in hardware. I boot up in safe mode and nothing change.
by
i send a photo how video looks like.
by
Sometimes you have to run the AHT 2 or 3 times for it to find a problem.
by
Add a comment
I also face same problem , i think it is from Ribbon problem which is used as a connector from Motherboard to LCD. You can try out by changing Once .
Add a comment
Add your answer
fgeorge86 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,345
