13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
A1278 mid 2010 logic board
Will the A1278 mid 2010 take an older logic board or only this year?
It started when I went to change out the screen. I tested the unit and it powered and booted to the desktop prior to dis assembly. Once we put it back together with the new parts it did not power on or show a charge light. I take laptops apart all day but have no idea how this happened
Is there something im missing?
Score -1
3 Comments
Can you supply the last three digits of your systems serial number to we can correctly ID the system you are trying to put the logic bd into and also give us the specs of the one your trying to put in.
by
Erik, does this look about right :"2.4 GHz Core 2 Duo (P8600)
Intro Date: April 13, 2010 Disc Date: February 24, 2011
Order No: MC374LL/A Model No: A1278 (EMC 2351*)
Subfamily: Mid-2010 13" Model ID: MacBookPro7,1
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive""
by
Yes that is it
by
Add a comment
Chosen Solution
As you didn't give us much to work with here to ID what you are working with. I looked up the mid '10 A1278 models here are the two that can interchange the logic bds without difficulty: MacBookPro5,5. Beyond this you will need to offer more detail of the replacement logic board.
Apple has changed the driver logic on the displays a few times so you can't just assume the board will work with the newer display.
1 Comment:
iti s an EMC 2351 LMK what other into is needed. I'm really apprehensive.
by
Add a comment
Best to stay within model years if at all possible. An older board may not connect or power your current display.
If this Answer is helpful please remember to return and mark it Accepted.
2 Comments:
Any idea what could have happened?
by
Reassembly problems.
by
Add a comment
Hi Erik
It sounds as if the reassembly of the DC board went wrong.
Taking an older (or younger) logic board needs to replace several other things, like cables or e.g. the display cover which is different sometimes (got one, which has different mountings for the cards in it), the shape of the logic board itself (think of the ones with one fan and the others with two).
Regards, Stone
Add a comment
Add your answer
Erik will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,347
