Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
No input / output sound devices, no startup chime
Hello
I have got a (second) MacBook 17" 2.93 GHz C2D unibody from early 2009.
Last days I noticed, that the sound devices (input / output) disappeared in preferences pane.
Also I do not have any startup chime.
I reset NVRAM / PRAM, SMC and also I took off the battery and interestingly, this helped from time to time. Lets say 2 out of 5 attempts to get it back to life are successful.
Also I repaired file system permissions.
I checked it by installing Win7 with boot camp, but also the sound devices do not appear in Windows.
It seems to be the fact, that if I do not switch on the MacBook for 1 or 2 days (or even longer) and switch it on then, the sound devices appear again; also sometimes the volume keys on the keyboard do react very, very slow (took about 2 or 3 seconds until I get the sign on screen after pressing).
I tried it by installing Snow Leopard, 10.6.8, and Mountain Lion, 10.8.4 - no difference at all.
Any suggestions?
Thanks, Stone
Score 1
Add a comment
Chosen Solution
As a work around you could use a USB audio adapter, USB audio is independent of on board analog audio. Some of these have built in microphones... most have audio in/out ports.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
9 Comments:
Hello MacHead3
Thanks for your answer - yes, this would be a workaround, but I would love to find out, what 's wrong.
I ran AHT extended version and it does not find any issues.
Regards,
Stone
by
Some times you have to run AHT extended mode 2 or 3X for it to point out a problem.
by
Ok, I will try this and let you know about.
by
After trying also some WD40 I think it is a hardware issue, need to strip down the MB and have a closer look to the output jack ... but I think, it is not the jack.
by
Yesterday I had some time and decided to let the AHT run as suggested, as suddenly the startup chime reappeared. I was watching a movie on DVD then for about an hour or two and had no problems ... as I put the movie to background in order to check mails and reopened the movie afterwards, the device was still "available" but I had no sound anymore; also the function keys for volume reacted very, very slow and after a reboot, the MacBook turned to total silence again ... cannot understand this and it is definitely not reproducible.
I installed Linux on it and it recognizes a MC97 HDA sound device, but I got no sound from the internal speakers (I think HDA will only work with HDMI connected device).
I am a little bit lost :-(
Regards,
Stone
by
Show 4 more comments
Add a comment
Most Helpful Answer
It sounds like if both the input and output device is gone from the sound panel on OS X it must be a hardware failure. OS X can not communicate with the device even if it finds it. The chips are on the logic board so it sounds like you need a logi board repair. Do you see a light inside the headphone jack? Not sure it would help since the digital output can hang sometimes and needs to be reset. But if OS X does not list in and output devices it can not communicate with them and it seems to be a hardware failure.
Score 2
2 Comments:
Yes, I do think it is a hw issue. There is no light inside the jack. I am thinking of a broken soldering, as it seems to work under some kind of heat and little pressure.
Will have a closer look this evenibg, also taking measurement with a scope.
Regards, Stone
by
I was about to purchase a second hand MBP non retina 2012 with these symptoms (**no audio output device listed in Sound Properties**) from a guy who sold them (not very technical guy though). The computer had a red light coming out the headphone jack (however digital output was not showing up either as a device) and no chime/bong on start up. I'm glad I didn't buy it; seems that the issue is the audio chips on the logic board.
by
Add a comment
Add your answer
Stone will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 6
All Time: 7,929
