Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
MacBook does not work on AC power
MacBook stopped charging the battery and will not work with AC power adapter only.
MacBook notices the connected power adapter, but reports battery not charging. Adapter light stays green even when battery needs recharging. MacBook runs fine on battery power. Installed battery update 1.4. Checked the battery (Cycles 66, Condition: good; does charge on onther MacBook). Checked the AC adapter (works fine on other MacBook).
Logic board failure?
Any other thoughts?
Update
got no applecare for this MacBook.
read somewhere a faulty connector could be covered by legal product warranty (production fault)
Score 1
Add a comment
Chosen Solution
Since it works with the battery and not the adapter probably the magsafe board is bad. I'm including the url's for the repair and the part. Ralph
MacBook Core 2 Duo Magsafe Board Replacement
MacBook MagSafe DC-In Board
Score 1
1 Comment:
Agreed. + I would also try using some contact cleaner on any corroded surface.
by
Add a comment
Most Helpful Answer
Power flows from the AC adapter, to the DC-in board, through the logic board and battery connector, then finally to the battery. There obviously isn't anything wrong with the battery or the AC adapter because they work on a known good machine. Therefore, it is something internal.
I would suggest opening the computer and checking the battery connector first. There have been a quite a few computers I have worked on and there was some corrosion in between the battery connector and the logic board. If there is then you need to replace the logic board and then battery connector.
Hopefully there isn't any corrosion and you can just replace the DC-in board.
Goodluck!
MacBook MagSafe DC-In Board Image
Product
$19.99
Score 1
Add a comment
follow up:
re Jethro:
- is the DC-in board (only) a connector, or does it contain electronics ?
- visual inspection of the battery connector shows no corrosion.
re Ralph:
- if the DC-in board is a connector only, I find it hard to believe this can malfunction.
- if so, can a claim for repair be covered by an (extended) applecare warranty ?
MacRuud
1 Comment:
If you still have AppleCare and it hasn't gotten wet, take it in. Come back here after the warranty has expired.
by
Add a comment
Add your answer
MacRuud will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,673
