Model A1046 or A1095 / 1280x854 screen resolution
118 Questions View all
Question Closed
PowerBook Al 1GHz - 4 Beeps at Startup
received today a AL Book
seller said that it beeps 3 times, but unfortunately - it beeps 4 times (light flashes 5 times) - so the boot rom should be faulty
is there any way to fix this problem?
Add a comment
Chosen Solution
The boot rom is not on the hard drive but in a flash memory module on the logic board (just like the integrated memory modules). The boot rom is an instruction set that the computer use before loading the OS. I think the boot rom can only be modified by a firmware update.
Score 2
4 Comments:
thanks for the reply the problem would be, that there is no firmware update listed (or i'm to blind to find it)
was there a ASD for the 1ghz or was the ASD starting at the 1,33 (but then would the ver. # 2.5.7 would not make much sense) - a simple yes or no answer to this particular question would be enough
by
If the boot room module itself is faulty I think that means a logic board replacement. If the boot rom image is corrupted maybe it can be reflashed but I really don't know (Google search..). Also the boot rom module might be physically replaced by a working one (salvaged from a dead board) again I don't know if it can be done....Sorry
by
ok thanks,
i will try something with the ASD, also found some firmware images - but first i will read a little bit more about that - in the morning, it's almost 12:38 am - bedtime ;-)
by
to "close" this question: i sold the powerbook - the buyer has a good logicboard for the beautiful case (no scratches or something else) - well, some things can not easily fixed - the only way would have been an otherwise toasted board, swapping the chips would have been the easiest way to fix it
by
Add a comment
Here's Apple explanation of the different startup beeps: http://support.apple.com/kb/HT1547
Score 1
5 Comments:
Good info + Ralph
by
right, but can the 4 beep problem be fixed ?
by
First thing I would do is zero out the hard drive to eliminate boot block problems
by
I replaced the hdd - same beeping
there is nothing on the screen, wont boot from the setup disk (optical drive is ok, took one of my spare drives)
by
What's your status on ASD issues? I have the 3S123 with updates 2005.06.07 & 08. Have anything to trade? Contact at mayer@door.net
by
Add a comment
Hi' Usually means bad ram slot. (Usually) the bottom one) Try removing the ram in the bottom slot and see what happens. Ralph
2 Comments:
that would bee the 3 times beeping - but 4 times is a boot rom error
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
by
You are correct sir--see mayer's answer. Ralph
by
Add a comment
You can read this page from Apple on the issue to see what the problem is.
You have a bad boot ROM. Back in these days, there was no real way to recover the BIOS as there is today. You will probably need a new motherboard that works to fix the problem.
2 Comments:
I know that problem, but i find it hard to believe that there is simply no way to fix a "minor" problem like that
by
The swap should be the easiest job, i have the tools and a'm able to use them - getting a otherwise fried board is the problem.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 3,831
