Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Questions View all
MacBook Air No Video 2008 Model
I have a 2008 macbook air with no video on the display or on an external monitor. It boots to the desktop as I can turn the volume up and down. Also, the keyboard backlight comes on when in a dark room. There is no image at all on the lcd even when a flashlight is shined on it. I have tried reseting the SMC and PRAM with no results. I'm wondering if I need to reflow the video card or maybe there's an onboard fuse I can replace?
Score 2
1 Comment
I just tested it with the built in display unplugged and the external monitor works. When the display is plugged in, neither the external monotor nor the built in display works. They both get signal for a split second then the external monitor goes back to sleep,
by
Add a comment
1 Answer
Chosen Solution
Sorry to hear that. You have a good logic board but the display is dead. Before saying such, please reseat the LVDS, the Display Cable connected to the logic board. That cable is on the left side of your logic board when you open it. It's a flatter one. Pull this out and place in carefully. Now turn on and see it it helps. Otherwise, you have to change the display assembly. The whole display with clamshell. You can only replace the display, but the job is really serious. Even the techs destroy the screen film which is quite fragile.
If you liked it, mark as accepted please. Thanks.
2 Comments:
I tried that and it didn't work. If it is the display I guess it could be in the cable. Maybe it's shorting out somewhere. If the display is bad then I might as will try taking it apart and see if it's a cable issue.
by
I successfully took the display apart and found the problem. The LVDS cable was slightly unplugged causing a short I guess. The hinges were extremely loose and probably wiggled the cable loose overtime. It works like normal now.
by
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,459
