0
Score
Avatar
Valantis
Asked
internal lcd connector to logic
History
have an iMac 21.5" the pins on lcd internal connector and removed some pins from the board while attempting to replace the hard drive. can someone help me?
already use machine to stuck them but nothing.. only some light on lcd when i power on the imac.. also if i use second screen is ok.. i will post some photos to see..
Edited by: machead3 ( ) , Valantis ( )
You broke pins off the logic board?
mayer,
Post Answer
2
Score
Avatar
Dan
7.9k
Answered
PermalinkHistory
Ouch!
Looks like you pulled off the header plate from the main logic board with a few pins broken off with it. Not much you can do here on your own. The logic board will need to be fixed if it can be. Often the traces get damaged when you tear off a component/connector like this.
If you can find someone with the correct skills and parts they maybe able to put a new connector on to the logic board (you take the risk of it not working after it's fixed $$). Otherwise, you'll need to look for a logic board to swap out.
In either case it will be expensive. Given the age of the system you might want to think about getting a new system Vs fixing this one, and selling this system for parts. Chalk it up to as a learning experience - Sorry ;-{
0
Score
Avatar
machead3
22.4k
Answered
PermalinkHistory
This sort of repair is not a DIY project. An electronics shop might take it on, they would have the tools and experience required.
If this answer was helpful please remember to mark it accepted.
Add Your Answer
