Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Tried to install a new battery
Not sure how the antenna grounding clip goes back in. I no longer get a signal. Is there a picture or something that shows how the clip goes back in?
Score -1
Add a comment
Chosen Solution
From iFixit's guide.
Score 2
Add a comment
Do the phone say "Searching" all the time, even when there is no sim-card installed?
If so, I had the same problem, which will be solved by putting the time/date settings to manually, then set the time to the correct values and restart the phone! :)
EDIT: the antenna clip goes in with the copper plate-side down against the contacts beneath, and with the litle "lever" with the golden top upwards, against the backplate.. this should be pretty easy to see in the pictures..
Score 1
Add a comment
Add your answer
tim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 441
