Tried to install a new battery
Not sure how the antenna grounding clip goes back in. I no longer get a signal. Is there a picture or something that shows how the clip goes back in?
Do the phone say "Searching" all the time, even when there is no sim-card installed?
If so, I had the same problem, which will be solved by putting the time/date settings to manually, then set the time to the correct values and restart the phone! :)
EDIT: the antenna clip goes in with the copper plate-side down against the contacts beneath, and with the litle "lever" with the golden top upwards, against the backplate.. this should be pretty easy to see in the pictures..
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 441
