Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Question Closed
Home Button Without Replacing Cable
I want to switch colors of my digitizer. The kit I am looking at just has the button not the whole Home Button Assembly. How is this button held on to the cable, the standard adhesive they use to hold other parts on? Do you remove the button with a heat gun? TIA
Add a comment
1 Answer
Chosen Solution
Yes, it is held by the standard double-sided adhesive that Apple uses in many places of the iPhone. Gentle use of a heat gun can be used but is not necessary. Just carefully pry the Home Button part you touch from the Ribbon part.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 405
