Xbox One Wireless Controller 1697 Troubleshooting
Troubleshooting page for the Xbox One Wireless Controller.
Controller Will Not Connect to Console
“I want to navigate my Xbox One, but my controller refuses to connect or will not stay connected for very long.”
Low Battery
Your batteries might be low. If the battery is low, the controller's wireless signal strength may be weak and therefore cannot connect to the console. You will want to replace the batteries.
Interference from Another Wireless Device
Conflicting signals may be the cause of the connection problem. Consider turning off nearby wireless devices and reconnecting the controller.
Too Many Controllers Connected
Ensure that you have not connected more than eight controllers. This is the limit for the Xbox One console.
Controller Inactivity
If you leave the controller idle for more than fifteen minutes and return to an unresponsive controller, you may need to turn the controller back on.
Controller Out of Range
Your Xbox One controller has a signal range of 30 feet (9.1 meters). Ensure you are within this range.
Controller Not Synced
If you have synced the controller to another device, you will need to re-sync it to the console. To do this, turn on your Xbox One and press and hold the "Sync button" on the controller. At the same time, press and hold the "Sync button" on the console until the indicator light on the controller starts flashing rapidly. Once this happens, release the sync button. After about five to ten seconds, your controller should be connected.
Finally, turn off your wireless router for a few seconds, then turn it back on.
Microphone Preventing Connection
Some people have reported that the controller will not connect with a headset microphone plugged in. Unplug the microphone and reconnect. If necessary, after establishing the connection through synchronization, plug the microphone back in.
Controller Will Not Turn On
“No matter how many times I try to connect or sync my controller, it will not turn on.”
Low Battery
Low Battery Pack
Your battery pack may be completely drained. Use a USB cable to plug the controller into the console. To check the battery's charge status, press the Xbox button to go to the home screen; the battery level is in the bottom right corner of the display.
Defective Charging Cable
Your charging cable may be faulty and will not charge your controller at all. If this is the case, you will need to purchase a new power cord.
Sticky Buttons
“One or more buttons on my controller take longer than usual to pop back up.”
Dirt Build Up
There may be tiny dirt build-up or sugary drink residue inside the controller. You will want to see our button replacement guide so you can reach the buttons to clean or replace them.
Faulty Thumbsticks
“I am unable to navigate my Xbox One correctly.”
Residue Build Up
Your thumbsticks may be sticky or not rotating correctly. Check the Thumbstick Replacement guide so you can reach your thumbsticks to clean or replace them.
Broken Thumbsticks
It is possible that you have been gaming a bit too hard, and one or both thumbsticks are bent or broken. See the Thumbstick Replacement guide to see how you can get back to your hardcore gaming habits in no time.
Controller Will Not Vibrate
“My controller refuses to vibrate when I am playing games.”
Vibration Setting Not Enabled
Ensure that your vibration settings are enabled. This can be done in the settings of the game you are playing.
Low Battery
If the battery is low, the controller may not vibrate in order to save battery life. Replace the batteries or charge the controller.
Vibration May Not Be Supported in Game
Try using another controller with the game you are playing. If the controller still does not vibrate, it is very likely the game does not support this option.
Defective Oscillator Motor
If you have already tried all of the above and your controller still refuses to vibrate, it may be caused by an issue with the oscillator motor. Prepare to grab your screwdriver, as you will need the [navigation| 36558 | Trigger Rumble Motor Replacement] guide.
Special thanks to these translators:
100%
Richard is helping us fix the world! Want to contribute?
Start translating ›
0 Comments
