Shop the Holiday Gift Guide
Does Not Charge
Jacob Ruiz and 1 contributor
Last updated on
When you plug in the charger into the V-Moda Crossfade II Wireless, is it not charging? Use this troubleshooting guide to help diagnose why.
Causes
A bad charging cable can cause your device not to charge. The charging cable can have rips and tears from constantly twists and bends. Another sign that you have a bad charging cable is that the cable can be very loose and not fully connect to the adaptor.
  • Try to use a different charger.
  • Use a different wall outlet or adaptor.
  • Make sure no wires are sticking out.
2
The USB port tends to clog up with dirt and grime after a while, so make sure to look at the USB port and see if its dirty. Some causes of build up is constant use of device, lint from casing, and even sweat.
  • Clean the USB port with a clean isopropyl alcohol rag.
  • Use compressed air to blow out the dirt.
Make sure not to poke to hard or it can cause damage to the USB port.
3
Constantly leaving the device plugged in at 100%, leaving it uncharged for a while, or just having the device for a long period of time can cause a battery to degrade.
  • Try a hard reset by holding the power switch in the pairing position for 10+ seconds.
  • If the hard reset does not work, the battery would need to be replace with a new 3.7V Lithium-ion polymer battery.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:5
Past 30 Days:50
All Time:204
