Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Overheating
Excessive heat being produced causing performance issues.
Blocked Air Vent
Make sure that there are no objects covering the air vents around the sides or on the bottom of the device. Clean off any dust that may build up around the fan vents. The fan itself may collect dust over time. Clean it off with some pressurized air.
Faulty Fan
Check to make sure that the fan is on by looking inside and feeling for a breeze while the device is powered on. If the fan does not spin, consider replacing it.
Fan Noise
Grinding or clicking sound occurring while the fan is spinning.
Loose Object
There may be loose cables hitting the fan as it rotates. Remove the back panel and tape or glue any obstructing cables out of the way.
Worn Fan Bearing
The fan bearing wears down over time. Access the fan and apply 1-2 drops of oil on the bearing. If the problem remains, consider replacing the fan.
Scratched Lens
There may be a small scratch visible on the front lens.
Missing Lens Cover
Scratches can be prevented by using the provided lens cover while in transport. Due to the anti-glare coating on the lens, do not apply any polish. Attempts to fix a scratch may cause further damage to the device and is not recommended.
Device/Display Does Not Turn On
When the devices is properly plugged in, it will not power on.
Faulty Cable
Burn marks or melting on cables could indicate that your device is overheating. Replace these immediately and see the Overheating section above.
Loose Cable
Make sure all cables make the proper connections by reinserting them. The cables still work if there is a flicker in the image while moving them around. If this does not solve the problem see other troubleshooting options.
Severed Cable
Look for exposed wires on the display and power cables. Any cable with exposed or severed wires should be unplugged and replaced immediately.
Blown Bulb
The bulb can burn out over time. If you are able to hear the fan spinning and the LED indicators on the top are working, this could mean that the bulb has burned out. See this guide on replacing it.
Blown Fuse
In the event of a power surge, if the device is not plugged into a surge protected outlet, the internal fuse will blow to save the projector. See this guide on replacing the fuse.
Vertical/Horizontal Lines in the Image
The may be vertical or horizontal lines present on the displayed image.
Loose Cables
Wiggle the cables to make sure that they make full contact with the connector. Consider replacing old or worn out cables.
Dirty Lens
Take a soft, damp cloth and wipe off the lens. Do not use excessive force or chemicals here because it could damage the anti-glare coating.
0 Comments
