Shop the Holiday Gift Guide
Overheating
Keion.M.Shelton and 1 contributor
Last updated on
Is your TopTro TR25 unusually hot and/or shuts off on its own? Use this troubleshooting guide to help diagnose why.
Causes
Typically, projectors of any kind operate better in air-conditioned rooms. If the temperature of the room exceeds 95-degree Fahrenheit (35 degree Celsius), projectors overheat more frequently. A solution would be to lower the room temperature to between 68-degree Fahrenheit to 77 degrees Fahrenheit (20 degrees Celsius to 25 degrees Celsius).
2
Anything could hinder the airflow in the projector which could cause overheating. Your best bet would be to check if there is any dirt, dust, large build-up etc., in the vent or dust filter. If there is any, it can be most likely removed using a basic air duster or other cleaning options such as a dry towel. Replace the dust filter if needed.
3
First, check the fan see if there is anything blocking the fan. If there is blockage, remove the blockage. After the blockage is clear and the fan still isn't working, it could be broken and just needs to be replaced.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:6
Past 30 Days:39
All Time:512
