Shop the Holiday Gift Guide
Unresponsive Buttons
Causes
If the buttons are unresponsive, it's very possible that the buttons themselves are stuck due to the buildup of debris, such as dust or grime.
To troubleshoot this, first inspect the buttons for any visible debris. Then, check to see if the buttons feel physically stuck or mushy.
If they do, or if you see any visible debris, dampen a cotton swab with isopropyl alcohol, making sure it's damp but not soaked or dripping, and then Wipe around the edges of each button. Dry off any excess with a cloth or dry cotton swab. Repeat as necessary until the buttons are visibly clean and the buttons don't feel stuck.
Another likely cause for unresponsive buttons on the Sonos Roam 2, like other Bluetooth devices and wireless speakers, can become unresponsive due to a temporary firmware glitch.
In this case, all you'll you need to do to fix this is hold the power button for about 5 seconds until the speaker powers off. Wait a few seconds, and then power the speaker back on. Test the buttons to see if this resolved the issue.
Starting with the your Sonos Roam 2 speaker powered on, you will press and hold the power button for five seconds to power it off. If done correctly, there will be a chime and the status light will turn off.
Press and hold the Play/Pause button, while holding that you will then press and release the power button. You will continue to hold the Play/Pause button until the front light flashes orange and white, then you are ok to release it.
Once the light flashes green you'll then want to press and hold the Bluetooth button until the light flashes blue. It should then appear on your phone as a device ready to connect, click on it and the light should turn to a solid blue indicating a stable connection.
Related Problems
Sonos Roam 2
5 problems · View all
Describe your problem in your own words
