Shop the Holiday Gift Guide
Audio Is Muffled
Causes
Devices like SPOT X SPOTXB currently need software updates to help them solve bugs or access new features. To check if any software update is available, check these steps:
- Establish a connection between the SPOT X and the SPOT app called "SPOT X," available on both the app store and Google app
- Look for upgrades that may resolve any audio problems
When it comes to devices such as SPOT X SPOTXB, falling can significantly damage the system, impacting the ability to hear and be heard from the device. We can perform a soft or hard reset to the system to fix that.
- Try to perform a soft reset. Switch off the SPOT X and turn it back on after a brief period. This can fix any transient bugs that might be causing problems with the audio.
- If the device is still not working, try to perform a hard reset by following these steps.
- Power Off: Turn off the device by holding the power button until the power menu appears, then select "Power Off."
- Remove the Battery: Remove the device's battery. Wait for about 10 seconds before reinserting it.
- Press and Hold the Power Button: With the battery back in place, press and hold the power button for 10-15 seconds.
- Release and Restart: Release the power button, then turn the device back on.
Several things could expose your device to moisture, including rain, spilled liquids, putting them in a puddle or lake, and high humidity. A lot of exposure can permanently damage your device’s audio or cause it to malfunction.
- Use 91% isopropyl alcohol to wet the fabric.
- Use the fabric to clean the device parts when they are in contact with moisture.
- Soak the device for at least 12 hours in a bowl of rice to dry it.
- Repeat the procedure to remove any water traces from the headphones.
Related Problems
SPOT X SPOTXB
2 problems · View all
Describe your problem in your own words
