Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Rotor Is Broken Or Will Not Spin
One of the four rotors is either visibly damaged, or will not spin fast enough to provide lift.
Broken Rotor
Remove damaged rotor(s) by unscrewing the top screw. The drone should come with replacement rotors, make sure you look at the letter on either side of the center, and match that to the correct arm of the drone (ie. if the arm has an A on it, make sure you connect one of the two replacement rotors labeled with A).
Rotor Is Not Secure
Make sure the rotor is screwed in all the way. The drone comes with a screwdriver meant for rotor replacements, ensure that each rotor is tightened securely.
Motor Is Disconnected Or Broken
You're going to have to open the drone up. Follow this guide to replace the motor.
Drone Will Not Power On
The drone won't respond to power button
The Drone Is Out Of Power
Make sure the drone's battery is sufficiently charged. The drone came with a USB charging device. Unplug the battery from the drone and insert the charging plug, then plug the USB into a computer, or power adapter. The lights will flash green while charging. The lights will turn steady when the battery is fully charged. A full charge will take about 140 minutes, and last for about 12 minutes of flight.
The Battery Is Broken
If you've tried charging the battery and no lights come on, first double check that the device or adapter you are using to charge the battery is functional. If it still doesn't work you can follow this guide to replace your battery.
The Main Circuit Is Broken
If the battery has charge, but the drone will still not power on, you may need to replace the main circuit board. Follow this link for instructions on how to replace the circuit board.
The Remote Is Out Of Battery
Remove the screw on the back of the remote, then pull on the tab to the right of the screw. The back panel should come out, then you can replace the four AA batteries.
VR Picture Doesn't Work Properly
The VR picture either doesn't work or doesn't look right.
Your Phone Isn't Set Right
Make sure your phone is sitting evenly inside the VR headset. If you have a large case on your phone you will probably need to take it off. Also, make sure that the app for the drone is set to VR mode, you will know it's working when you see the same image split twice on your screen side by side.
The VR Lens Is Broken
If one of the lenses looks cracked or significantly scratched, you'll need to follow this guide to replace it.
The Camera Is Broken
If the problem seems to be with the drone itself, first make sure that you've properly connected the app to the drone. Connect your phone to the wifi signal that your drone outputs.
Author
with
Austin Fedie
168 Reputation
1 Guide authored
UW Stout, Team S8-G6, Ogden Spring 2018 Member of UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 Members
48 Guides authored
40 Comments
How do you connect to the same wifi?? Does it pops up on the phone. I have 3 different wifis in the house
Charles Taylor - Reply Share
Let me know to cuz it won't pop up on my phone at all
Anthony Pescetto - Reply Share
SO i returned the kaptur gps 2 to walmart thinking the drone was broken because it wouldnt connct to Wifi and the replacemnt wont connect either. Did you get yours to connect?
Joe Lucero - Reply Share
Go to wifi settings click wifi and kaptur should populate. If not disconnect from the house wifi then it should be there connect to it.
mp5disney - Reply Share
how to set flight range , mine is stuck on 96 feet ?
messedup_71 - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 8,339
