Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Drone Does Not Lift Off
Drone's rotor blades will spin for a second and stop.
Dead/Low Dronium One Battery
This is caused by low or dead battery on the drone itself. Dronium One uses a 3.7V 380MAh Li Bo battery and can be charged using a computer USB. To resolve this issue, carefully insert the charging cable into the drone USB port.
Solve this issue by replacing the battery here.
Drone Does Not Respond to Controller
The drone is in working condition, but will not follow commands from the remote controller.
Dead/Low Controller Battery
This may be caused by low or dead battery on the controller. Remove the battery cover and insert 4 ‘AA’ batteries (+ side into + side). Put the battery cover back on.
Controller and Drone Not Synchronized
Follow the simple steps to synchronize the controller and drone:
1. Turn on the controller.
2. Turn on the aircraft and place it on level ground.
3. Move the throttle stick all the way forward and then all the way back.
A plausible problem is that electromagnetic objects may interfere with the communication between the drone and the controller. Therefore, remove any electromagnetic objects such as batteries, magnets and other objects surrounding the drone that can cause interference from the mediate area, and always fly in a clear opening.
Previous Physical Damage
If your drone has suffered any physical damage in the past, such as crashing into the wall or falling from great heights, this may affect the drone’s ability to respond to the controller. Loose cables or connections can prevent communication. Inspect drone visually and reconnect any unconnected cables.
If damage is visible on the Rotor Blade or Rotor Guard, the replacement guide to solving this issue can be found here.
Rotor Blades Do Not Spin
You can hear the motor functioning but the rotor blades do not respond.
Motors Are Set in Opposite Directions
You can fix this remote control (RC) motor by checking if the rotor blades are connected to the right motors. Another solution is to change the wires that are connected to the motor. To do so, inspect underneath the drone’s arms to make sure the cables are not intertwined and only go to each individual rotor gear.
Drone Tilts When in Flight
Your dronium tilts when in flight due to the following potential errors.
Loose rotor blades
Even though your dronium works, an error with the rotor blades can cause the drone to tilt when in flight. This happens when one or more rotor blades are loose or wobbling. For an example, propeller A, B and C is spinning normally and propeller D is spinning loosely. To resolve this issue, turn on the dronium without lifting it off and observe the rotor blades. When the loose propeller is found, hold it in place while turning the motor on and it will tighten itself. Also, you may tighten the propeller screw if you have a compatible screw driver.
Flying the Drone at an Angle
If you see your drone flies at an angle after lift-off, this means that your drone was not placed evenly on the ground prior to lift-off. To resolve this issue, place the drone on a flat surface and be mindful of elevation angle prior to lift-off. The surface could be leveled but the landing gear is damaged.
If that’s the case, the replacement guide to solving this issue can be found here.
Motors are Spinning with Different Speeds
If the drone is not at a level platform, it may attempt to compensate by accelerating some of its motors. Verify that the motors are connected property and check to make sure the drone is level when it is on the floor at take-off.
Irregular or Erratic Response From Control Inputs
The drone might show irregular or erratic response from the control input.
Radio System Failing
The drone might fail to respond to the radio system because of the electromagnetic interruption, possibly caused by magnets and other electrical devices. Another reason is that other objects are blocking the signal, causing the drone to fail from not receiving the signals. If the drone does not respond to the radio signals, remove any electrical devices or magnets that might cause interruption.
Remote Control Antenna is Damaged
Similar to the radio system failing, the remote-control antenna could be damaged because of the electromagnetic interruption caused by magnets and other electrical devices. One way to fix this is to remove any magnets or electrical devices that could cause the interruption.
Solve the issue by replacing the antenna here.
Ameth Ramos
537 Reputation
5 Guides authored
USF Tampa, Team S2-G5, Sullivan Spring 2017 Member of USF Tampa, Team S2-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G5
4 Members
60 Guides authored
19 Comments
Amazing guide
Tanginator - Reply Share
Was flying out of my house, had a small crash and tackle into a drape. All four spin, but when I touch one of the propellers at spinning it seems like it's not locked in place the rest of them are spinning locked in place. When I take off it flips towards the weak side spinning. Any suggestions ?
Mark Miller - Reply Share
Make sure u have correct blade in motor a or b I had same prob replaced with correct blade and bingo
Jared Bobo - Reply Share
I got all four blades to spin and locked in but it still tips over when it goes to full throttle. Anybody have any suggestions?
Mike, please add this question into the support section so that more people can read it and help!
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 38
All Time: 10,723
