Protocol Dronium One Controller Antenna Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
82
All Time:
727
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your drone does not respond to the controller, the antenna could be the issue. The following guide will help you to replace the antenna in the controller.
Tools
    1. Protocol Dronium One Controller Antenna  Replacement, Controller Antenna: step 1, image 1 of 3 Protocol Dronium One Controller Antenna  Replacement, Controller Antenna: step 1, image 2 of 3 Protocol Dronium One Controller Antenna  Replacement, Controller Antenna: step 1, image 3 of 3
      • Remove the six 8.8 mm screws located on the back panel of the controller using a Phillips 000 screwdriver.
      Ask FixBot
    2. Protocol Dronium One Controller Antenna  Replacement: step 2, image 1 of 1
      • Carefully lift off the back panel of the controller.
      Ask FixBot
    3. Protocol Dronium One Controller Antenna  Replacement: step 3, image 1 of 2 Protocol Dronium One Controller Antenna  Replacement: step 3, image 2 of 2
      • Then, pull the antenna up and out of its location.
      Ask FixBot
Ameth Ramos
537 Reputation
5 Guides authored
USF Tampa, Team S2-G5, Sullivan Spring 2017 Member of USF Tampa, Team S2-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 82
All Time: 727
