Shop the Holiday Gift Guide
False Button Inputs
Tessa Baldwin and 2 contributors
Last updated on
If your PDP Victrix Gambit Prime Wired Tournament Controller has issues with misfire or late response, follow this troubleshooting guide.
Causes
In some cases, excessive wear and tear or even dropping the controller may lead to false input or analog stick drift.
  • Before moving further, ensure that the buttons on the controller have not received critical damage or visible cracks.
2
Over time, every controller will come across a build-up of dust and grime between the electrical components.
  • What are the various steps to take to ensure and prevent a dirty controller?
    • Unplug the controller to prevent any further damage
    • Use a lightly damp cloth to wipe down the controller
    • Finally, use a cotton swab or a toothpick to carefully remove any build-up in tight crevices
3
The PDP Gambit Prime controller has a cable that connects to the console and a faulty cable may lead to an unresponsive controller.
  • What to search for in a faulty cable inspection?
    • In some cases, the cable will have exposed wire so make sure to disconnect the cable first
    • Make sure the cable is connected thoroughly in both ways
    • Check for debris, in both the connector and socket of the device
    • If they all don’t work, search for a different power supply.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:7
Past 30 Days:51
All Time:398
