Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Oregon Scientific Meep! 4.0 Will Not Turn On
No matter what you do, the Meep! will not turn on. Please consider the following possibilities.
Faulty Power Switch
When pressing the power switch, nothing happens. The circuit may not be properly attached to the motherboard or there may be debris blocking the switch, which does not allow it to properly reach the on position.
Shortened/Drained Battery Life
Attempt to charge the Meep! until it is 100% charged. If it still does not turn on, it could be a bad battery that can no longer power up. If the Meep! does turn on, but only lasts for a short period of time, the battery could be drained from being overcharged constantly. Oregon Scientific Meep! 4.0 Battery Replacement guide will help you with replacing the battery.
Photos Show Up Black
When you try and take a picture with the camera of your Meep! the screen appears all or mostly back.
Dirty Camera
When the camera application of the Meep! is opened, the screen is almost or completely black. Check to make sure that the camera isn’t blocked and is free of dirt or debris. Very gently, use a dry cloth to clean in and around the camera.
Broken Camera
You cleaned the camera of your Meep! and the screen is still black. This could mean that the camera is not functioning properly or is broken. In this case, the camera will have to be replaced.
Photos Fail to Upload to Computer
When trying to upload the photos from the Meep! to a computer, the photos fail to transfer over to the new device.
Faulty USB Port
Check to see that the USB port is free of debris before plugging a cable into it. Use a dry cloth to wipe down the area to clean any dust or debris.
Broken USB Cable
If the device does not respond when plugged in, check to see that the USB cable isn't torn or bent. Damage to the USB cable can cause performance issues. If this is the case, a new replacement cable should be purchased.
Screen is Unresponsive
Press the power button. If you are unable to see anything on your screen, the display on the device may need to be replaced.
Damaged Screen
This problem is simple to detect, if the screen is cracked, the Meep! might be on but will not provide any illustrations for you to see. It can be hazardous to use a device with a cracked screen. This guide will help you with replacing the screen.
Faulty Screen
The screen might be sensitive to touch. If overused, the screen will no longer respond when specific buttons are pressed. Sound will come out to detect the device is on but the screen is either black or frozen.
Device is Unresponsive
Screen is Frozen
If illustrations are present but not moving the unresponsive device may also be frozen. Check to see if the sound is working, if so, activate the reset button located on the back
of the device.
Motherboard is Broken
If the device is not responding to anything you do, the motherboard may be broken and will need to be replaced. This guide will help you replace your motherboard.
Device Does Not Register Voice Commands
You try talking to your Meep! but it doesn't seem to be hearing you.
Microphone is Broken
If the device is not registering your voice commands, make sure that nothing is blocking the microphone. If it is still not working, follow this guide to replace your microphone.
No Sound Comes from the Device
While using your Meep! no sound is coming from the device.
Speakers are Broken
After making sure that the device is not on mute, no matter how high you turn up the volume, no sound is being emitted from the device. In this case, the speakers could be broken and will need to be replaced. Use this guide to replace the speakers.
Jess Forte
434 Reputation
4 Guides authored
5 Comments
Hello
I hope someone could help me
My meep device in not alowing me to enter to the parental controle!! And everything is loked accept the videos musics pictures so how can i fixe this problem ?? Or please tell me where is the right place to ask question because this website (oregonscientific.fr) is not working !
Email: kabkosai@gmail.com
Kosai Kab - Reply Share
I can not get it to stay on
Teresa Vann - Reply Share
My power switch is broke
No OT on the screen to upgrade
Jackie White-Woto - Reply Share
I can't even set up the parental controls because every time I open it it's not really responding and says session timeout you have been logged out from parental settings press okay to proceed then it'll say try again later on the second retry
josia griffin - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 43
All Time: 1,678
