Shop the Holiday Gift Guide
Moving Slow
Last updated on
  • Restart your computer/Restart mouse if needed: Restarting your device can sometimes fix temporary glitches or clear out any temporary files that might cause issues. Be sure to shut down your computer completely, turn your mouse off, and remove the batteries to ensure the mouse can fully power cycle.
  • Replace your mouse's batteries: If you're using a wireless mouse, check to see if the battery is low or close to being depleted.
  • Check system resources: If you have a program taking up an absurd amount of memory or CPU power, then this can cause your mouse to move more slowly than normal. Open your system's Task Manager or Activity Monitor to see if any programs are taking up a large amount of your system's resources.
  • Install pending updates. Install the pending updates. Vendors frequently release patches or updates to software to enhance its responsiveness and reduce resource consumption. Windows updates can be found in Settings > Updates and Security.
  • Try recreating the issue on a different computer: Try seeing if the issue is persistent between devices. If the issue is persistent, then the issue is likely with the mouse.
Causes
Solution: Clean the Mousepad and Mouse Optical Sensor
Dust, debris, or hair on the mouse pad or the mouse sensor can interfere with its tracking. Under ideal conditions, you would want to make sure the sensor is as clean as possible and that the surface you are using your mouse on is both clean and level.
  • Clean your mousepad: Most modern mice use optical sensors to track a surface. If the surface your mouse is tracking is dirty, then this can result in poor tracking. If you are using a mouse pad, then you are going to want to make sure that the surface of that mouse pad is clean. You can use a soft-bristled brush to remove most debris that could impact tracking.
    • You can also perform a deep clean by soaking your mouse pad under lukewarm water with a mild soap, and gently scrub with a microfiber cloth or sponge. Be sure to run it thoroughly and let it air dry completely.
  • Dirty sensors or worn feet: Dust on the optical sensor can impede tracking. Gently clean the sensor window with a dry cloth and some high-concentration alcohol. Also check the mouse feet/’skates’ for wear – replace them or use tape to restore smooth gliding if needed.
2
Solution: Increase cursor sensitivity
Cursor sensitivity is a setting that allows a user to either increase or decrease the speed at which their cursor moves. If the sensitivity is accidentally reduced significantly, then this can result in slow movement.
Windows 11
  • From the Windows 11 desktop, select Start and then select Settings, Bluetooth & devices, then Mouse.
  • Once in the Mouse window, use the slider next to Mouse pointer speed to set the mouse pointer speed.
Windows 10
  • From the Windows 10 desktop, select Start and choose Settings, Devices, then Mouse.
  • In the Mouse window, adjust the Cursor speed by using the slider.
MacOS
  • On macOS, open System Settings, then click Mouse or Trackpad from the sidebar.
  • Click Point & Click, then drag the “Tracking speed” slider to your desired speed.
3
Solution: Update mouse drivers
An outdated or corrupted mouse driver or system driver (USB or Bluetooth adapter) can slow or destabilize cursor movement.
  • MacOS and Linux operating systems will use a generic driver for mice; however, if your mouse's manufacturer has drivers available through their website, then try downloading the latest driver software from the manufacturer's site.
  • Windows 10 and 11 will automatically search for new drivers; however, you might need to prompt the operating system to install the latest drivers. Hit the Windows Key and I to launch the settings application, and choose Windows Update from the left menu. From there, simply select the Advanced options and Optional updates, then Driver Updates to search for the driver for your mouse.
Important
Keep in mind that if Windows isn't able to find and update automatically, then you may also need to go to the manufacturer's website.
4
Solution: Try a different USB port/Avoid USB Hubs
If your mouse is connected to your computer via a USB hub, the problem might be a bandwidth shortage. USB hubs can introduce latency or slow down data transfer, especially when other high-bandwidth devices like external hard drives are simultaneously plugged in.
  • Try plugging your mouse directly into your computer. If your computer uses USB-C while your mouse uses USB-A, then you might need to invest in a USB-C to USB-A adapter.
  • If not using the dongle isn't optional, then try removing any storage devices or any devices that might be drawing power. This should increase bandwidth and reduce any sluggishness of your mouse.
5
Solution: Replace broken components where needed
If none of the above helps and the mouse behaves the same on another computer, the mouse itself may be faulty.
Important
Replacing damaged components will require you to have some soldering knowledge. Consider taking a look at our Soldering Skills section and our guide for How To Use a Multimeter.
  • Dissassemble the mouse and look for any burnt or damaged components: Check for any signs of burnt or water-damaged components. If you observe any visible damage, the mouse's mainboard should be replaced.
  • Check if the sensor's lens is scratched or cracked: A cracked or damaged lens can greatly impact how your mouse functions. If the lens is damaged, then the lens or the whole sensor may need to be replaced.
  • Ensure that the mouse's red LED illuminates: Most optical mice use a red LED to illuminate the surface beneath the mouse. This light is used to help the sensor capture movement and then translates it into cursor movement on the screen. Ensure that power is being delivered to the LED, and the LED itself isn't burnt out. Try testing this with a multimeter.
  • Replace the optical sensor: Ensure that the optical sensor is getting the proper amount of power by testing the component with a multimeter.
Describe your problem in your own words
View statistics:
Past 24 Hours:24
Past 7 Days:139
Past 30 Days:506
All Time:3,942
