Shop the Holiday Gift Guide
Audio is Not Clear
Ethan Abbott and 1 contributor
Last updated on
If your Logitech UE Hyperboom speaker's audio is not clear or the speaker has no audio even when the device is powered on, follow this page for possible solutions.
Causes
If the Speaker has power and is producing audio when pressing a button or turning on or off, your Bluetooth may be turned off causing the speaker to not connect and preventing it from producing audio.
2
If the speaker is powered on and the device is connected the volume on either device may not be turned up to an audible volume. Try pressing the '+' button on the speaker or pressing the volume up button on your connected device
3
The Logitech UE Hyperboom features a Bluetooth connection for a range up to 150ft. Any farther may result is audio crackle or cutting. Move the Bluetooth connected device closer to the speaker.
4
Audio distortion may be caused by the battery running out of charge. Charge up the speaker to ensure it has enough charge before resuming use.
5
It is possible that audio problems could be a result of a small technical problem. In this case you might need to factory reset the speaker. To do so, turn the speaker on and hold down the power and play/pause button simultaneously for around 5 seconds. An audible cue should play, and the speaker will turn off. You can now turn the speaker back on.
6
If none of the above steps resolve the issue, it is possible that the internal speaker component may have been damaged or is malfunctioning and will need to be replaced. Refer to our speaker replacement guide for instructions.
Describe your problem in your own words
View statistics:
Past 24 Hours:7
Past 7 Days:14
Past 30 Days:55
All Time:256
