Shop the Holiday Gift Guide
Is Not Charging
Causes
Some internal cables may become bent over time as the device is used. This could cause a bad connection between the USB port and the motherboard, causing the device to not charge. To fix this, you will need to open the device, unplugged from charging, and carefully locate the white ribbon wire connected to the USB port board. Once located you will have to unplug the ribbon wire connector attached to the USB port, straighten the connecting end, reconnect the connector, and put the device back together.
It is possible that the internal USB to motherboard connector may come loose over time. This could result in no connection between the USB port and the motherboard, causing the device to not charge. To fix this, you will need to open the device, unplugged from charging, and carefully locate the white ribbon wire connected to the USB port board. Once located you will have to unplug the ribbon wire connector attached to the USB port, reconnect the connector (making sure it is snug), and put the device back together.
Related Problems
JBL Flip 6
2 problems · View all
Describe your problem in your own words
