Shop the Holiday Gift Guide
Battery Not Charging
Taehwan Kim and 2 contributors
Last updated on
When your Flydigi Vader 4 is plugged in the battery may be slow to charge or not charge at all. Follow the steps below to allow efficient charging of battery.
Causes
If your Flydigi Vader 4 Pro is plugged in but the battery is slow to charge or not charging at all, ensure you are using the provided USB-C cable. Avoid using high-voltage phone "fast chargers" as these can sometimes prevent the controller from drawing power. For the best results, charge the controller directly through a PC USB port or a standard wall adapter.
2
Dead batteries can be caused by excessive use of the console or bloat. If your Flydigi Vader 4 battery is dead you will need to replace it with a new one. A new battery can be ordered online, but it is necessary to order a battery with a 2-pin JST-PH connector. Users can check the condition of their battery by referring to the [battery_replace_guide]
3
Your Flydigi Vader 4 Pro should hold a charge for anywhere from 15-20 hours, when charged to 100 percent. If battery life is significantly lower than this battery replacement may be necessary. Users can check the condition of their battery by referring to the [battery_replace_guide]
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:27
Past 30 Days:102
All Time:646
