Shop the Holiday Gift Guide
Camera Mechanism Does Not Move
Causes
The gimbal may also be not calibrated correctly. Re-calibrate the camera and gimbal by following these steps:
- Power on the drone and controller.
- Open the DJI GO app and tap on the camera icon in the top right corner.
- Open the menu from the top left corner and select “Gimbal Settings”.
- In this screen, select “Calibrate Gimbal”.
- Follow the instructions from there.
A common error during gimbal calibration is to neglect to turn the gimbal wheel left and right after doing full stick movement.
Check the connections, if any are loose or broken, depending on the extent of the damage, it may need to be replaced. The ribbon cable can often get damaged and end up needing replaced.
Also check for any debris or anything else blocking the wheel that would obstruct the movement of the gimbal.
Check out this replacement guide if the gimbal is broken and needs to be replaced.
Related Problems
DJI Phantom 3 Standard
5 problems · View all
Describe your problem in your own words
