Shop the Holiday Gift Guide
Lights Flashing
David Rios and 3 contributors
Last updated on
If you experience flashing lights when your DJI Phantom 2 Vision drone is on, follow this troubleshooting guide.
Causes
  • The Phantom 2 Vision’s LED lights located on the drone are mainly used to indicate where the front and back of the drone are from far away. The front LED lights will turn red only after spinning the device’s propellers. There are only a few abnormal status indicators.
2
  • If the Phantom 2 flight indicator LED lights are quickly blinking yellow, then the signal with the remote controller has been lost.
    • To ensure that the controller can connect without initiating the failsafe, The remote controller’s antenna should be pointing skyward, relatively perpendicular to the ground with no obstacles in the way.
    • After checking the antenna, simply reconnect the controller to fix this issue
3
  • If the Phantom 2 flight indicator LED lights are slowly blinking yellow, that indicates you are in ATTI mode and you have lost GPS signal.
    • Move to an open area to fly the drone with minimal interference, and it will automatically switch out of ATTI mode. Until then, you will need to fly manually without assistance, relying solely on remote inputs, which requires a high level of skill.
4
  • If the lights are slowly blinking red, then the battery power is running low.
    • To charge the device, Connect the USB-C charger or PD fast charger to the USB-C port of the charging hub. The corresponding LEDs will change to solid green when the battery is fully charged.
5
  • If the lights are solid red on the back lamps, then there has been a critical error and the device cannot fly. Try to connect to the Phantom 2 Assistant Software for more details on the specific error. You may need to recalibrate your device.
6
  • If the lights are blinking between red and yellow, then the device’s compass needs to be calibrated.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:8
Past 30 Days:59
All Time:692
