Up to 20% off select tools
Anker Soundcore Space One Play Pause Button Unresponsive
Jack Lawrence Farago and 1 contributor
Last updated on
When pressed, is your Anker Soundcore Space One's play/pause button unresponsive? Follow these comprehensive steps to get your device back into usable order.
Causes
If the sensors are affected in any way due to a variety of reasons, it could affect how the buttons react to touch, making them seem unresponsive.
  • The touch sensor of the device might not register if you press it right away. It could take a second to react.
  • Sweaty hands, high temperatures, or humidity can interfere with the sensor that detects when you're wearing the device, leading to issues with the play/pause function.
  • If the ear cups are dirty, then the sensor may not register correctly.
  • Wipe off any moisture, cool off the device, and put the device in an area that has low humidity. Try the button after the device isn't being affected by any external factors.
2
If the lock screen on a device you're trying to connect to is locked, the play/pause button can't be used.
  • Some music apps might behave differently when the device is locked, which could impact the play/pause button's responsiveness.
  • Unlock the screen and try again.
3
If multiple sources of audio are playing simultaneously, the play/pause button has a harder time differentiating them, causing it to not work properly.
  • Ensure multiple audio-playing sources aren't open to avoid confusion in the play/pause button's command reception.
  • Clear all audio sources and try the button again.
4
If the device you're trying to connect to doesn't have the necessary commands, it could stop the play/pause button from working.
  • The music player cannot be controlled when a Windows computer is locked. Unlock the screen and try again.
  • Some devices do not respond to the device's play/pause command.
  • The device can only control audio players. There's a chance that video apps will not respond to the device's play/pause commands.
5
If the Bluetooth system in the device isn't set up properly, it could hinder how some of the buttons operate.
  • Put the device into pairing mode.
  • Try pressing the play/pause button again to see if it has resumed functionality.
6
Sometimes, the problem could be that you are pressing the wrong button. In this case, the play/pause button might still be operable.
  • Check the user manual that came with the device to confirm the correct button combination for play/pause.
  • Take some time to get familiar with the layout and functionality of your device.
7
The lack of newer software updates for the device might be the cause for the play/pause button being unresponsive.
  • Update the device to the newest version.
  • Try the button again to ensure it works.
8
If debris or dirt accumulates between the ear pads, it might affect the button's functionality. If they're damaged, it could also affect functionality. Follow the guide "here" to replace it.
9
If the headband has a severe break, it could impact the wires wrapped inside the headband, preventing needed signals and connections from reaching the buttons. Follow the guide "here" to replace it.
Describe your problem in your own words
View statistics:
Past 24 Hours:4
Past 7 Days:18
Past 30 Days:72
All Time:597
