Shop the Holiday Gift Guide
The Basics
Before undertaking any of the more time-consuming solutions below, these are a few fundamentals to get you started.
- Double-check system responsiveness—your system will not freeze if the clock advances. Too impatient to wait? Try using a different input to verify.
- Press the Windows key to see if the Start menu opens.
- Right-click your mouse or press any additional buttons to trigger a different response.
- Use the touch screen to navigate if your laptop has one.
- Force shutdown. Press and hold the power button for 30 seconds to force it off. This is as close as most modern laptops can get to disconnecting the battery without busting out the screwdriver set. Power back on and try to recreate the issue.
- Process Windows updates. You can check for updates in the Settings menu. Updates to Windows can improve compatibility and overall system stability.
- Are you stuck on the lock screen and can't get the password field to show? Press Ctrl + Alt + Del and pinch your fingers. Often, this will magically bring the login field into view.
Causes
If you use peripherals, such as an external GPU, docking station, or external hard drive, the issue might be caused by those peripherals.
- Disconnect all peripherals and reconnect them one at a time to see if they freeze when a specific peripheral is connected.
- Check the connections of any external peripherals to ensure they are correctly seated and functioning without issue.
- If a specific accessory is to blame, check for updates to drivers or affiliated software. These can usually be found at the manufacturer's website.
If your laptop freezes when running a particular program or a specific combination of apps, the issue could be caused by a lack of system resources.
- Double-check the system requirements for the application that you are attempting to run. Be sure to check for your RAM, CPU, and GPU requirements.
- If your Acer Laptop allows it, try upgrading its hardware. This process will be specific to your laptop.
- The most effective tactics will be more RAM or replacing an aging Hard Disk with a Solid State Drive.
Computers generate a lot of heat during significant processing workloads. If your Acer laptop is overheating, it might freeze or become unresponsive. This could be due to the system limiting processor speeds to generate less heat or because it hit a failure point and could not recover.
- Check the temperatures your hardware is reaching. Use Open Hardware Monitor or any other temperature monitoring software.
- Carefully inspect your laptop's vents and cooling system for dust or debris obstructing airflow.
- Make sure you are using your laptop on a smooth and level surface. Uneven surfaces, such as carpet or fabric, can block your device's vents and restrict airflow.
- Consider using a cooling pad designated for laptops to improve ventilation and reduce the risk of overheating.
If you recently reinstalled your cooling system, ensure your device has a proper amount of thermal paste. There should be a thin, even layer on top of the CPU with no air bubbles. To learn more about applying thermal paste, consider our guide on How to Apply Thermal Paste.
Computer viruses and other harmful software can wreak havoc on system stability. They might skate by unnoticed, but more likely, you'll end up with freezing, crashing, or other unexpected behavior.
- Scan your computer using an Antivirus. If you do not have dedicated security software, use Windows Defender. It can be accessed from the Windows Security App in most versions of Windows.
- Want a second opinion about your results? Malwarebytes or ESET Online Scan are free programs providing excellent malware scanning techniques.
- Many free malware removal tools are available, but a paid solution will be more effective. Be sure to verify legitimacy before using software from any unfamiliar developer, or you may end up worse off than before.
- Remove anything your scan finds. It may also recommend a restart to complete the removal.
- Contrary to intuition, more antivirus is not better. Multiple antivirus applications installed on a system cause more headaches than it solves. They may attempt to modify the duplicate system files, suck up additional resources, or even fight against each other. Uninstall all antivirus programs aside from whichever one you like best.
- Please keep reading through the OS Corruption section and process those fixes as well. Malware can damage Windows through infection.
OS corruption means critical system files have become invalid or damaged. This can occur due to powering off during an update, the battery dying during use, or malware. It can lead to irregular behavior, like freezing or other inconsistencies. Try some Windows repair tactics.
- Right-click on the Start Menu and run Command Prompt, Powershell, or Windows Terminal as admin. Windows 8, 10, and 11 will provide different options, but any of those listed will do the job.
- In the window that appears, type
sfc /scannow, then press enter. Once it has finished, it will tell you if it found errors and whether or not it could fix them. - Restart your system and run sfc again to verify no further corruption has been found.
- If additional errors cannot be cleared, or you need extra fixes, consult the Basic Windows Repair guide.
If you aren't concerned about losing your data, try the "Nuke Everything" approach and reinstall Windows.
- Windows 10 reset options are in Settings > Update & Security > Recovery.
- Try the "Keep Data" option first. This only reinstalls Windows and removes any applications. Your files will be
- For stubborn issues, use create a USB installer to install instead.
If you still cannot repair the OS or continue to experience freezing, your storage device may be to blame. A failed storage drive can also result in missing or incorrect data.
- Run diagnostics to verify the health of your drive. For a quick snapshot, use Crystal Disk Info. Even if this indicates "Caution," replacing the drive is recommended.
- If your drive has failed, navigate to the page for your model of Acer Laptop to find a drive replacement guide that works for you. If you can't find your particular model, follow a guide for a similar model; it can point you in the right direction, even if it's not precisely correct.
- If your device has a more traditional hard drive disk (HDD), consider replacing it with a solid state drive (SSD) for a performance boost. They are more energy efficient and much speedier.
$65.99
4.9
136 reviews
Find compatible replacement parts for your Acer Laptop. All parts and fix kits are backed by the iFixit Quality Guarantee.
Random Access Memory, commonly abbreviated as RAM, can cause repeat freezes. This is more likely to cause a crash, but specific symptoms may vary.
- Reseat your RAM modules. Numerous tiny pins could be slightly out of alignment. Removing them and reinstalling them might be all it takes to fix this.
- Test your RAM by running a diagnostic. Ideally, you would want to use Windows Memory Diagnostics.
- If you want a second opinion, IT Professionals have been using memtext86 for ages. It's a free tool, and its documentation is excellent! However, it will require a bit more knowledge to use.
- RAM tests are notoriously long, and minor failures are hard for tests to find. Trust diagnostic failures, but not passes. Multiple diagnostic runs may be needed to find an issue.
- If you recently upgraded your RAM or have more than one module installed, ensure the specs match. At minimum, speed and capacity should be identical.
- Replace the memory if diagnostics fail—either increasing the overall size or keeping the exact amount and speed.
Be especially mindful when replacing the RAM to get something compatible. Crucial has a compatibility checker for its products that you can use to validate.
If the above tips have failed, the issue might be caused by the motherboard. Damage to the motherboard due to physical trauma, electrical surges, or other hardware-related issues can impact functionality. A faulty motherboard can lead to erratic behavior, intermittent freezing, crashing, or system instability.
- Inspect the laptop's motherboard for signs of physical damage, such as burnt components, liquid residue, corrosion, or other visible issues. If you find any damage, replace the board or consult a pro.
- Most newer Acer laptops have their CPU soldered to the motherboard. If you suspect your freezing is related to a defective CPU, you must replace the motherboard.
- Circuit boards can often be repaired by a knowledgeable technician with soldering (or microsoldering) experience. If you don't think you could do this yourself, ask your local repair shops.
You're seeing solutions for Acer Laptop. Select your model to find parts for your device.
Related Problems
Describe your problem in your own words
