Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer is Too Hot/Won't Cool Down
While your computer is on, it becomes hotter than normal.
Faulty Fan
If your fan malfunctions, try replacing it with a new fan using this guide.
Clogged Ventilation
Open the bottom of your Chromebook with a Phillips PH0 screwdriver. Unscrew the single screw opposite to the battery of the Chromebook. Once unscrewed, carefully pop off the back door of the bottom. Now go ahead and clean out any dust or debris around the fan itself or its air vents/intake. You can use air duster to clean the components. Once cleaned, place the back door back into bottom of the Chromebook and screw the screw back in tightly.
Battery Won't Charge
Your computer does not receive any power with your power supply plugged in to a functioning power outlet.
Faulty Battery
Using our guide remove the battery carefully and replace it with a new one.
Faulty Power Supply
If your power supply cables do charge your Chromebook, try using a different power supply cable to see if your power supply cable is not faulty. If this does not work, you can also try plugging your power supply cable into a different power outlet.
Computer Won't Connect to Internet
You have trouble connecting your computer wirelessly to the Internet.
Wifi Router Settings
Try looking under the wifi router settings and see if the router's DHCP service is turned on. Additionally, try checking the network settings on your Chromebook to see if your Chromebook is using DHCP. You access these settings by clicking on your account photo in the lower right corner of your Chromebook screen. Then click on Settings and find the Network section.
Wireless Signal Out-of-Range
If you are experiencing a weak wireless signal, try moving closer to your wifi router for a better signal.
Wireless Card is Turned Off
Try pressing the Fn + F11 keys to turn on the wireless adapter.
Faulty Wireless Card
Replace the wireless card using our guide.
Screen Will Not Display
Your computer turns on but nothing will display on the screen.
Brightness Settings
Try pressing Fn + F7 to see if the brightness is on the lowest setting. If you are using an external display, try increasing the brightness settings on that.
External Displays
Try disconnecting any external displays from the Chromebook to see if the screen signal was not being sent to the external display instead.
Operating System/Computer Won't Boot
Your computer turns on but will not go past the BIOS screen.
Faulty Hard Drive
Replace the hard drive using our replacement guide.
Corrupted Boot Files
Try reinstalling the operating system by using the Chromebook Recovery Utility app from the Chrome Web Store on another laptop running Google Chrome or Chromebook. Insert a USB drive of at least 4 GB into the other laptop. Run the Recovery Utility app, follow the prompts, and make sure you have your affected Chromebook's model number. Eject the USB drive after the utility is done and turn on your affected Chromebook. Press Esc + Fn + F3 then the power button and let go of them to open the recovery screen, insert the USB drive when prompted and follow the instructions.
Alan Bennett
88 Reputation
0 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
60 Guides authored
1 Comment
Anyone know how to swap out or connect all flex cables from the lcd main flex cable on acer chromebook - C710 I’ve been trying to finish repairing this PC since summer I can’t find any help. Just one cable I can’t find an connection for. Please Help. Thanks.
Anthony Williams - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 17
All Time: 777
