Shop the Holiday Gift Guide
is Not Connecting Wirelessly
cgrabowski1 and 1 contributor
Last updated on
Is your Asus ROG Spatha X powering on but will not connect wirelessly to the dock? Use this troubleshooting guide to help diagnose why.
Causes
Ensure that the Spatha and the receiver are powered on and have been charged enough to function wirelessly.
2
Refer to this guide for replacing the battery in the mouse, but instead of fully replacing the battery, just quickly disconnect and reconnect the battery
3
Ensure the Armoury Crate software is up to date, the latest version is installed and there are no pending updates
4
Ensure that the Spatha is actually in wireless mode, not wired mode, by checking that the switch on the bottom of the mouse is set to wireless mode
5
In some cases, a firmware reset may be required. To perform this, first plug in the mouse while in wired mode. Next, Unplug the mouse, then hold down left click + scroll wheel + right click. Reseat the cable while holding these buttons down. After about 20-30 seconds, you should see a popup to reset the firmware. Follow the on-screen instructions to complete the update
6
Ensure that the dock's USB cable is in good condition, is plugged into a free 2.0 USB port (not a 3.0) on your computer, and that it is placed relatively close to the mouse. Make sure to try the cable onto a different port on your computer if it is still not functioning properly
7
Check the USB cable connecting the dock to your computer for signs of damage or fraying. If none of the other above fixes have worked, try using a different USB-C cable
8
If all else fails, refer to this guide to replace the battery for the mouse.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:26
Past 30 Days:83
All Time:705
