iPhone 7 Plus Display Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 7 Plus Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 iPhone 7 Plus Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 iPhone 7 Plus Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Plus Display Assembly Replacement: step 2, image 1 of 3 iPhone 7 Plus Display Assembly Replacement: step 2, image 2 of 3 iPhone 7 Plus Display Assembly Replacement: step 2, image 3 of 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  3. iPhone 7 Plus Display Assembly Replacement: step 3, image 1 of 2 iPhone 7 Plus Display Assembly Replacement: step 3, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Plus Display Assembly Replacement: step 4, image 1 of 1
10 other people completed this guide.
Paige Reisman
23,604 Reputation
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 13
All Time: 5,477
