Shop the Holiday Gift Guide
Retroid Pocket Flip Troubleshooting: Fix Common Problems
The first step towards a working Retroid Pocket Flip is identifying the problem. Select one of our preferred guides below to diagnose and solve Retroid Pocket Flip common issues.
Joystick Not Responding or Drifting
If your Retroid Pocket Flip Joystick moves or registers input by itself, even when you are not touching it, follow the steps below to identify possible causes of the issue.
Hinge Is Loose or Not Holding Position
If you open or use your Retroid Pocket Flip, and the hinge feels loose or does not hold the screen in position as expected, follow the steps below to identify possible causes of the issue.
D-pad Inputs Not Registering
If you press the D-pad on the Retroid Pocket Flip, and some or all directions do not respond, respond only sometimes, or register incorrectly, follow the steps below to identify possible causes of the issue.
Didn't see your problem? The iFixit Community has answers.
Browse the most common questions asked by our members to see more solutions. Still no luck? You can always ask for help!
Battery compatible retroid flip?
Retroid Pocket Flip
Any compatible hinges for the retroid flip?
Retroid Pocket Flip
