Up to 20% off select tools
Evercade EXP Troubleshooting: Fix Common Problems
The first step towards a working Evercade EXP is identifying the problem. Select one of our preferred guides below to diagnose and solve Evercade EXP common issues.
Won't Power On
If your Evercade EXP does not power on when you press and hold the top-right button, follow these steps to ensure it starts correctly.
Battery Fails to Charge
When you plug the Evercade EXP and it fails to charge, follow these steps to ensure correct procedures to get the Evercade EXP charging again. Before taking any time-consuming measures, please ensure the following: Make sure you are connected to a power device with the correct power charger. The charger is a USB-C charger. Ensure the USB-C functions properly. Ensure the cable is not damaged. If you are using your charging dock, ensure the USB-C adapter is plugged in correctly and that the dock is not damaged
Encountering Directional Drift
When your Evercade EXP is powered on and not in active use, the directional pad still activates and creates inputs on the device. Follows these steps to stop the unwanted inputs.
Buttons Not Registering
If the Evercade EXP buttons are not functioning properly, follow these steps. If problems persist or these steps don't help, follow the manual page.
