Introduction
Have a look at the inside of Sony Xperia Z3 Dual and let you know where is component when need repair.
Witrigs is specialized in cellphone accessories and kinds of replacement guide.
Remove two SIM card trays.
Heat the back cover to soften the adhesive sticker.
Place the suction cup and to open a gap from top side.
Remove that blocker beside the earpiece speaker at first.
And then you can pry up the earpiece speaker and remove it.
This is bullshit. I broke my speaker by following those instructions. The part of the speaker facing away is glued to the front glass so trying to “pry up” separates the plastic case that holds the magnet and delicately attached membrane. The membrane is held to the magnet frame with glue, on the other side entire speaker is glued. It is obvious the weaker glue will fail first.
If I was doing it again I would simply remove the blocker and leave the speaker in its place and remove it after detaching lcd with front glass. Alternatively use heat on the top of front glass to weaken the glue before attempting to pry the speaker. I'm quite lucky I managed to buy a replacement speaker or I would have a useless phone after following those “instructions”.
Remove loudspeaker assembly securing bracket. And there is no any adhesive.
Pry up and remove the loudspeaker assembly. No adhesive, too.
The bracket as well as speaker assembly is very difficult to remove from a never disassembled phone. You have wiggle it, pry it, and bend it slightly to remove. Don't use force or it can be broken.
Also there IS adhesive surrounding the speaker aperture gluing it to the front glass. It is not a lot, but one has to be aware of it.
Removing those elements is the most difficult part of the entire disassembly.
Done.
This guide doesn't describe what is where on the phone. For example if you are replacing the screen no need to disassemble anything near the motherboard. Only the bottom. To disconnect lcd remove the metal bracket that is under the loudspeaker assembly. A piece of copper foil with glue on the connector might prevent access. Unstick sides of the foil and disconnect the connector. Then you need to gently heat the front glass to 80C (I used a hot plate and infrared thermometer - a piece of paper between the phone and hot plate) and then gently use plastic wedge to separate the lcd ribbon cable from the metal plate under it. It is held by some sort of metallic glue. Then you can u glue the front lcd glass same as you did the back.
9 Comments
Can you put it back together?
I dropped mine so I just want to take the battery out is it possibly to take it and then put it back in
hi.after changing my xperia z3 dual lcd 3 times.i hade a fluctuating and very week 3g and 4g signal.plz tell me where is the antenna located.i know that there is a flex and a board and antenna cover.what should i change.thanx
That's not a complete teardown. I would like to see the onboard chips and info's.
i need board from where i purchase please guaid me
Hi Sofiya,
That's a great write-up.
My mobile repair guy is attending my mobile (sony Z3- single sim) for antenna- it is unable to receive phone network signal properly. He says he has to replace the antenna mother-board. But from your write-up I don't find any such mother board- is my repair guy conning me?
Thanks
Sundar
how many this LCD ? rupiah
How much this LCD? Rupiah’s
