This teardown is not a repair guide. To repair your Rubik's Cube, use our service manual.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: step 1, image 1 of 3 Rubik's Cube Teardown, Rubik's Cube Teardown: step 1, image 2 of 3 Rubik's Cube Teardown, Rubik's Cube Teardown: step 1, image 3 of 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: step 2, image 1 of 2 Rubik's Cube Teardown: step 2, image 2 of 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: step 3, image 1 of 2 Rubik's Cube Teardown: step 3, image 2 of 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
    Rubik’s Cube BROKEN using this method on a cube with a Circular Center. Last corner piece snapped when pushing in. Not recommended to use ‘force’ as the little plastic pieces can’t withstand it.
    * This method only works if you have a Rubik’s Cube that looks exactly like the one in the video when disassembled! If your Rubik’s Cube looks different (circular center) DO NOT USE THIS METHOD!!!!!
    Booya Tribe - Reply
rab777hp
20,333 Reputation
3 Guides authored
OPEN Member of OPEN
Community
82 Members
25 Guides authored
6 Comments
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Reply
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Reply
my middle peices came out cant fix it
jax - Reply
can someone tell me how to fix it
jax - Reply
grr i am mad that i cannot fix my rubik’s cube!
Devin Plante - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 46
All Time: 24,573
