This teardown is not a repair guide. To repair your Power Mac G4 M5183, use our service manual.
  1. Power Mac G4 M5183 Teardown STEM Project, Case: step 1, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, Case: step 1, image 2 of 2
    • Pull the tab to open the case.
  2. Power Mac G4 M5183 Teardown STEM Project, RAM: step 2, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, RAM: step 2, image 2 of 2
    • Pull the white tabs down
    • Lift up the RAM
    • Repeat x4
  3. Power Mac G4 M5183 Teardown STEM Project, Heat-sink: step 3, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, Heat-sink: step 3, image 2 of 2
    • Use a flat head screwdriver or spudger to lift up the tabs that hold down the heat-sink.
    • Repeat x2
    • The heat-sink should just lift right off.
  4. Power Mac G4 M5183 Teardown STEM Project, GPU: step 4, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, GPU: step 4, image 2 of 2
    • Remove highlighted screw.
    • The GPU should lift right out.
  5. Power Mac G4 M5183 Teardown STEM Project, Mother Board: step 5, image 1 of 3 Power Mac G4 M5183 Teardown STEM Project, Mother Board: step 5, image 2 of 3 Power Mac G4 M5183 Teardown STEM Project, Mother Board: step 5, image 3 of 3
    • Remove highlighted cables.
    • Remove highlighted screws.
    • Lift out the motherboard. (Note: pull to the left to clear the ports from the case)
  6. Power Mac G4 M5183 Teardown STEM Project, CPU: step 6, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, CPU: step 6, image 2 of 2
    • After removing the screws, simply lift off the CPU from the connector. Use only a minimal amount of pressure when pulling the CPU from the connector.
    • This is the connector after removal of the CPU.
  7. Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: step 7, image 1 of 3 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: step 7, image 2 of 3 Power Mac G4 M5183 Teardown STEM Project, DVD/ROM drive: step 7, image 3 of 3
    • Remove the face plate. You are supposed to press down the highlighted tabs from the inside.
    • Slide out the drive. (MAKE SURE TO UNHOOK THE CABLES)
  8. Power Mac G4 M5183 Teardown STEM Project, Hard drive: step 8, image 1 of 3 Power Mac G4 M5183 Teardown STEM Project, Hard drive: step 8, image 2 of 3 Power Mac G4 M5183 Teardown STEM Project, Hard drive: step 8, image 3 of 3
    • Remove the highlighted cables.
    • Lift out the hard drive.
  9. Power Mac G4 M5183 Teardown STEM Project, Main Fan: step 9, image 1 of 2 Power Mac G4 M5183 Teardown STEM Project, Main Fan: step 9, image 2 of 2
    • Remove highlighted screw. ( SAME SCREW ON OPPOSITE SIDE, REMOVE THAT AS WELL.)
    • Disconnect the connector.
    • After that, just pull it out.
  10. Power Mac G4 M5183 Teardown STEM Project, Power Supply: step 10, image 1 of 3 Power Mac G4 M5183 Teardown STEM Project, Power Supply: step 10, image 2 of 3 Power Mac G4 M5183 Teardown STEM Project, Power Supply: step 10, image 3 of 3
    • Use a 2.5 mm hex key to remove these screws.
    • Feed the wires through the highlighted hole, then pull out the power supply.
  11. Power Mac G4 M5183 Teardown STEM Project, Finished!: step 11, image 1 of 1
    • You will be left with an empty case.
Harrison Case
128 Reputation
1 Guide authored
4 Comments
Just a little tip.
APPLE tend to use screw connections as a means of ground continuity.
That is - if the CPU card is not screwed down - it might not power on.
Mal - Reply
The is a kit from thelaserhive.com to allow an mATX board to be used inside the G4 cases.
Pete Karnowski - Reply
como retiro las tapas de los lados para hacerlelimpieza
martin alonso moncada gonzalez - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 49
All Time: 3,398
