Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
This teardown is not a repair guide. To repair your Nokia 8110 4G, use our service manual.
    Final Thoughts
    • For the most part disassembly is extremely simple with only plastic clips, and standard Torx screws holding the phone together.
    • The battery is easy to access and replace
    • Several main components such as headphone jack, SD card slot, Micro USB port and vibrator are soldered to the motherboard.
    • Getting to the display requires removing the front glass which is tricky to remove without damaging it.
    Repairability Score
    8
    Repairability 8 out of 10
    (10 is easiest to repair)
2 Comments
这种玻璃很难移除而不会损坏它。
这块玻璃屏在被移除时很容易遭到损坏
Hong DING - Reply
Very good teardown clip except did not show separation between tactile matte keymat and upper case.
Abbas Abdul Wahab - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 16
All Time: 11,978
